ABITS Training & Diagnostics Hardcopy Document - Published online - Chevy Impala SS Forum
 1Likes
post #1 of 23 (permalink) Old 03-23-2011, 11:39 AM Thread Starter
juniorwatson's Avatar
All,
I have taken several days & hours culling down the pertinent information that was listed in the YouTube video titled: LT1 Optispark (ABITS) Distributor Operation and Diagnostics.
The final product came to be a 28 page double sided document with close up detail shots, and detailed text on testing each sensor, and it appropriate reading.
It is available for ALL to have as it is on a public site callled 'Dropbox'
The site URL is: Dropbox
The Logon and password are as follows:
Logon: [email protected]
PW: dropboxshare
The Word document & 158Mb MP4 original file are located in the \ImpalaSSforum\ directory.
I thought it would be great to have a hard copy in a 3-ring binder in the trunk of the Impala/Caprice, just in case she does break down while away from the house. A DVOM, spark tester, and test light are all helpful tools as well.
Let me know what you think, and we can vote to have this sticked if deemed necessary.
(I PM'd BK for him to move it to the Engine Problem & Maintenance section, and also STICKY it)
Plus we ALL can use the Dropbox site for sharing files as well!
REVISION C PUBLISHED TODAY, 4/30/2011
1. The last image on Sheet 4 showing an E4 External Torx Socket is required to remove the distributor cap, and the tool and 1 screw shown for reference.
2. The last image on Sheet 5 showing the rotor and noting that it is held down by (2) (T9) screws and Loc-Tite should be applied upon reinstallation.
3. Top of page 7/32 I added the text stating that the Optical sensor is held down by (2) E6 External Torx screws.
I also did the following to the Dropbox site:
1. Changed DIR structure a little and removed the *.DOC master copy that I will keep myself for editing. If anyone has a problem with the .PDF format, contact me privately and we can make arrangements for a format that suits you best.
2. Updated the document slightly to show what Torx tools are required. The details are as follows, for the REV-C Document:2.
Last edited by juniorwatson; 04-30-2011 at 09:11 AM. Reason: REV-C Published and Uploaded
juniorwatson is offline
post #2 of 23 (permalink) Old 03-23-2011, 12:07 PM
Send a message via AIM to MidSSouth5-0
login no workie
~Stephen Yahoo IM: Sthrncop
96 SS, T56 BBHP #72, 4:10
05 Kawasaki Ninja 650R
Where did the pic of my car go?
MidSSouth5-0 is offline
post #3 of 23 (permalink) Old 03-23-2011, 12:21 PM Thread Starter
PW Updated, Sorry.
post #4 of 23 (permalink) Old 03-23-2011, 01:26 PM
SimplyTheBeSS's Avatar
Consider this stolen! Thanks!
1994 SS
SimplyTheBeSS is offline
post #5 of 23 (permalink) Old 03-23-2011, 02:26 PM
94MI9C1's Avatar
Thank you sir.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #6 of 23 (permalink) Old 03-23-2011, 02:57 PM
Moderator
Goldmaster's Avatar
Thumbs up
Thanks for taking the time to make this. Must have been a pain in the ass.
Goldmaster is offline
post #7 of 23 (permalink) Old 03-23-2011, 03:19 PM
95_9C1's Avatar
Thumbs up wow !
excellent work - thanks
95_9C1 is offline
post #8 of 23 (permalink) Old 03-24-2011, 08:13 AM
Eracer's Avatar
noice !
The whole aim of practical politics is to keep the populace alarmed (and hence clamorous to be led to safety) by menacing it with an endless series of hobgoblins, all of them imaginary.
H. L. Mencken
Eracer is offline
post #9 of 23 (permalink) Old 03-24-2011, 08:28 AM
RJI
Thanks! Got it saved
Please visit my website at: http://www.1finecaprice.com/
RJI is offline
post #10 of 23 (permalink) Old 03-24-2011, 08:49 AM
95BRMW's Avatar
Thanks for taking to time to do this, good to have a handy glove box guide!
1996 DCM SS 216k
1996 Black RMW 158k
1995 DCM Roadmaster Wagon 118K
1992 Olds CC 5.3l LS swap 181k
1994 Fleetwood 160k
1975 Impala Coupe
95BRMW is offline
