Can't find Deutsch BF412 - Page 2 - Chevy Impala SS Forum
 1Likes
post #11 of 14 (permalink) Old 06-11-2016, 01:16 PM
Originally Posted by Brick B-Body View Post
The easiest way to look it up with a parts store is by application. Ask for a breather filter for a 1988 Ford Tempo.
From what I can figure, this breather filter was used on all the Ford 2.3L 4 cylinders of this vintage. The 1988 Tempo is right in the middle of the age range for this engine, and was only available with the 2.3L in 1988. This helps cut down on screw ups at the parts counter.
Here are some of the part numbers that work:
AC Delco: FB131
Baldwin: SA4137
Deutsch: BF412
Motorcraft: FA 1118
Purolator: B23165
WIX: 66501
Here is what the current Fram packaging looks like. Also some size pix with a quarter for reference.
Do you know if it passes visual? I had a problem when I replaced it with another PCV valve.
Gmpar is offline
post #12 of 14 (permalink) Old 03-28-2019, 08:43 AM
DeuceSS's Avatar
Yes, i know this is an old thread....Just posting for posterity
Hastings part # CB36
Breather is not serviceable as it was held together with some glue or exoxy, but certainly came apart easy enough. I suppose if one was frugal enough they could replace with a filter/breather media of their choice at a designed service interval
DeuceSS is offline
post #13 of 14 (permalink) Old 03-28-2019, 04:23 PM
1. As I said before, I replace that silly lil pasta elbow with a
AC Delco: FB131 / Baldwin: SA4137 / Deutsch: BF412 / Fram: BA6592 / Hastings: CB36 / Motorcraft: FA 1118 / Purolator: B23165 / WIX: 66501
on the passenger side valvecover's fitting.
2. I then splice a a NAPA 3299 fuel filter into the same line, between the 88 Ford Tempo's breather filter and the throttlebody.
3. I then splice another NAPA 3299 fuel filter into the PCV line that goes to the inlet manifold.
(Catch Can would probably work better than a fuel filter. One catch can might even work better than the two I'm using.)
4. In place of the Gen2 LT1 old style PCV valve, I use the Gen4 SBC PCV thing (12572717).
Every 18 months, I replace #1, #2, & #3, 6 months apart. Have not needed to replace #4 yet, just blow it out with compressed air every 6 months.
DeuceSS likes this.
1g1bl82p7rr127841 RIP,IP
Marky Dissod is offline
post #14 of 14 (permalink) Old 03-28-2019, 05:08 PM
DeuceSS's Avatar
Thanks Marky for the always informative post.
Yes, i did install an unmolested filter and will be installing a catch can once i delete the ABS unit. i currently have a filter inline with pcv.
I plan on using the ABS bracketry and location for catch can (i Think)
I had only posted the pictures because through my research i couldn't find any pictures of the internals, and certainly not to discount RJI's comments but he referenced it as a baffle and it piqued my interest.
and yes i also have the newer pcv valve which i believe i got from an H2
DeuceSS is offline
