data log review - Page 2 - Chevy Impala SS Forum
post #11 of 43 (permalink) Old 03-24-2019, 11:17 AM Thread Starter
I sent these logs to pcmforless who did the mail order tune but they refused to even look at it unless the log is taken in datamaster or freescan.
94 Impala SS- 388 LTx, AFR 210cc heads, Lloyd Elliot cam, 11.67:1 compression, Nitrous Outlet 200 shot
old setup: Procharger, etc...520 RWHP
70 El Camino SS 396
72 Chevelle
70 Chevelle convertible
70 Chevelle hardtop
94SSman is offline
post #12 of 43 (permalink) Old 03-24-2019, 11:38 AM
babywag's Avatar
Originally Posted by 94SSman View Post
The check engine light works but has not been on. I'll contact eehack and see why I am getting this error. Without being able to read my own logs there's not much I can do. I may just trailer it to the tuner to be safe.
Withh all those random errors and weird data @ times I would not try to have it tuned.
Something is wrong and needs to be resolved.
babywag is offline
post #13 of 43 (permalink) Old 03-24-2019, 11:44 AM
Originally Posted by babywag View Post
Looked @ log closer. You have some weirdness going on. Lots of error codes popping up momentarily and data way off sometimes? How is your wiring? Good clean grounds? Need to take a good look @ it.
A crappy OBD cable will inject a lot of garbage into the datastream
Amazing you even got something that runs from them. That place is well known for ripping people off. From what I can see, your tune is driveable - there's nothing there that screams 'danger to manifold!'. The knock counts are high - but are you hearing ping at all? If not, it could be false knock, buuuuut it could also be real knock that you just can't hear.
What heat range plugs are you running? At 11.5:1 you should be about two heat ranges cooler than stock. Also, your 52mm is most likely doing just fine on that mill.
atlantadan is offline
post #14 of 43 (permalink) Old 03-24-2019, 01:46 PM Thread Starter
I got the cable from moates.net.
I haven't heard any knock at all and the car drives great with no problems. It idles good when warm and cold.
I was running NGK TR6's when the data logs was taken but I have NGK BR7ES's that just arrived. Those are 2 heat ranges cooler than stock and it is what was recommended by Nitrous Outlet.
70 El Camino SS 396
72 Chevelle
70 Chevelle hardtop
94SSman is offline
post #15 of 43 (permalink) Old 03-24-2019, 02:03 PM
I am running those same plugs. They will help with the knock counts, but you still may have to get in those cells and pull some timing out. I am surprised that you're getting those errors with a Moates, so it's probably not the cable. Make sure everything - and I mean everything - is otherwise inactive/off on the laptop you are using. Including your firewall and antivirus. The last thing to try is to update the FTDI drivers, as something may have gone sideways.
Once you get the knock counts down (if at all) then go in and start looking at fueling. Pull the timing out, flash, re-log the car and see what you see. If you don't see any real change by pulling 10 degrees out, then its probably false knock. For fueling, once the laughing gas comes into the game, I'm out of my league.
post #16 of 43 (permalink) Old 03-24-2019, 02:35 PM Thread Starter
This is the error message eehack gives me.
70 El Camino SS 396
72 Chevelle
70 Chevelle hardtop
94SSman is offline
post #17 of 43 (permalink) Old 03-24-2019, 03:07 PM Thread Starter
Photo of plug attached.
70 El Camino SS 396
72 Chevelle
70 Chevelle hardtop
94SSman is offline
post #18 of 43 (permalink) Old 03-24-2019, 03:13 PM
Broken definitions file for eehack. Under settings/advanced, you'll see it there. Search around for a new replacement file - they're all over the web.
post #19 of 43 (permalink) Old 03-24-2019, 04:03 PM
babywag's Avatar
From Steve posted on his site...
broken definition file, there are three ways to go here.
first, to reset the settings completely. in your start menu, my installer installs a ‘reset all settings’ shortcut (in the ‘advanced’ submenu). you can use that.
second, you could find the key in the registry at HKEY_CURRENT_USER\Software\EEHack\fbodytech.com and fix it (or remove that one key so it’ll default)
third, simply rename or move the definition that’s crashing it, then fire it up. eehack, on being unable to find a definition file, will lock itself up and prompt you to find a new one.
…i intended to do that re-selection routine when you run into an ‘invalid’ file too, but never got around to it…
babywag is offline
post #20 of 43 (permalink) Old 04-13-2019, 02:00 PM Thread Starter
I've been trying to get eehack working for weeks. I started by uninstalling and reinstalling but that didn't work. The link in Steve's post is dead. How do I find the definition file that is crashing it?
70 El Camino SS 396
72 Chevelle
70 Chevelle hardtop
94SSman is offline
Similar Threads
Why is my '96 SS running so poorly? w/ Ultra-Gauge "data log" video! kpeters59 Engine Problems/Maintenance 26 04-21-2011 01:10 PM
is my torque converter slipping? data log included ahoora PCM Programming/Engine Management 3 01-10-2010 09:23 PM
What do I need to log data? Richlough Caprice 1 10-13-2009 08:20 PM
Data Log SSoreal PCM Programming/Engine Management 0 04-13-2009 07:54 PM
Stock Data Log? gollygwagen Engine Performance 0 02-13-2004 10:54 AM
