OBD1 Impala - Chevy Impala SS Forum
 2Likes
post #1 of 14 (permalink) Old 06-03-2019, 03:06 AM Thread Starter
cadejohnson58's Avatar
OBD1 Impala
I just have questions about what pins in the OBD1 12 pin port to use for putting a male dupont connector in it, then a female connection on the board looking device to then have a laptop hook up to my car. I'm pretty sure it's just three wires but dont know which ones in the OBD port. And I'm wondering if there's anyone else doing this.
cadejohnson58 is offline
post #2 of 14 (permalink) Old 06-03-2019, 09:35 AM
babywag's Avatar
TX/RX on adapter tie into aldl wire on obdi connector
GRD to aldl ground wire on obdi connector
I usually just soldered the jumper wires directly so there is no chance of a poor connection or loss of connection while flashing.
But you can also just plug wires directly into obdi port.
babywag is offline
post #3 of 14 (permalink) Old 06-03-2019, 03:23 PM Thread Starter
Okay perfect then the male's should go in the OBD port and on the other end the female's go onto the laptop USB adapter pins then a mini USB cord to connect laptop. I'm sure there are legit cable's but I've been told to stay away from Red river so this is my new plan thank you for your input.
post #4 of 14 (permalink) Old 06-03-2019, 04:14 PM Thread Starter
I think this is everything. I'll start looking up OBD1 pin locations thank you for your help!
post #5 of 14 (permalink) Old 06-03-2019, 09:41 PM
babywag's Avatar
Should work...been using similar for years.
sherlock9c1 likes this.
babywag is offline
post #6 of 14 (permalink) Old 06-04-2019, 02:03 AM Thread Starter
Thank you, you spliced in the wire it looks clean I might do that. Can I ask what company you went with for this maintenance of your car. My goal is to see exactly what's happening and for mods down the road I don't wanna send a PCM in the gentle care of postal service all the time.
post #7 of 14 (permalink) Old 06-04-2019, 09:25 AM
babywag's Avatar
I do all my own stuff. Nobody touches my car(s).
jiml likes this.
babywag is offline
post #8 of 14 (permalink) Old 06-04-2019, 02:20 PM Thread Starter
Can I ask what computer program you use and are happy with
post #9 of 14 (permalink) Old 06-04-2019, 03:19 PM
babywag's Avatar
tunerpro & eehack
babywag is offline
post #10 of 14 (permalink) Old 06-04-2019, 07:19 PM Thread Starter
I appreciate your help man.
