Gun sight Delete - Chevy Impala SS Forum
post #1 of 15 (permalink) Old 11-14-2006, 09:16 PM
BigFleetwood93
looking to do this little mod
first question Recomended style of emblem?
I was going to go with the Allante grill
or like the one on the deville concourse
second do you use some sort of Adhesive do you use?
anyway thanks
[ 11-14-2006, 10:32 PM: Message edited by: BigFleetwood93 ]
post #2 of 15 (permalink) Old 11-14-2006, 10:16 PM
ocjmakaveli
Aww don't recommend it you won't shoot the same afterwards. Don't cut off the caddys manhood
post #3 of 15 (permalink) Old 11-14-2006, 10:53 PM
96 Black
Recommended style of emblem over the hole?
No? Slapped on the grille?
I did an Escalade rear on my front, but was told with my 2nd one that they either did or will soon discontinue it separate without being glued to the colored keydisk. Find an Escalade and you'll know what I mean.
I had to rout out the grille to make the emblem lay flush, and had to relieve the crest in the middle and bend it to make it form to the grille bow curve - used 5 minute epoxy.
I bought that new DTS rear deck crest-n-wreath for the trunk and the angle matches perfect without modding. When I do the front again I'll just get a new stock grille and try that back one on the front too.
post #4 of 15 (permalink) Old 11-15-2006, 05:53 AM
yellowtaws6
I used a emblem I bought on eBay. It was plastic and had 3M on the back. I heated it with a blow dryer and bent it to fit the peak in the center of the grill.
I took it off because I liked the gun sight alone better [img]smile.gif[/img]
post #5 of 15 (permalink) Old 11-15-2006, 08:03 AM
96 Black
Yellow-,
Once I get past the glare of all that chrome . . . .
I think I see the issue. That paltry grille emblem was scaled perfectly to merely compete with the sight. Losing one or the other was a good call. BTW, I wish my Silverstars would burn out after over 4 years so's I could look into them neat lights you got.
Big-, whatcha' gonna do man? You got to be mighty manly to carry off an emblem as big as mine.
post #6 of 15 (permalink) Old 11-15-2006, 12:12 PM
BuickMaster
just wanted to post because you guys gave me the idea to do the grille emblem on my RMW (see sig pic). just can't decide if i wanna shave the hood hole or put a emblem there also (since i don't know how to shave).
post #7 of 15 (permalink) Old 11-15-2006, 02:12 PM
Brackets
Wink
Or you could just leave it off.
post #8 of 15 (permalink) Old 11-15-2006, 02:26 PM
BigFleetwood93
thanks for all the help gents
96-Black, I like the look of yours...but I get what your saying
Im going to go with the DTS style up front and in back...bit question is how to get it to stay on...I will dremel out the grill like you said, so its flush.
thanks alot
post #9 of 15 (permalink) Old 11-15-2006, 05:01 PM
chris joyce
Hey brad, I always loved ur grill set up. How did you get the mesh to stick? What kind of mesh did you use? Did you paint the entire grille the color of the car?
post #10 of 15 (permalink) Old 11-15-2006, 07:30 PM
Brackets
Thanks Chris, when I had the hole filled in the hood I also had the grille, headlight and taillight trim painted. The mesh is extruded aluminum and I attached it to the back of the grille by drilling some small holes in it and tie wiring it with stainless.
