traction control - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 01-12-2007, 10:48 PM
ras282
My traction control has been real sensative lately, if I hit a little pump in the road the traction control kicks on.Has anybody had this problem?
post #2 of 8 (permalink) Old 01-13-2007, 08:46 AM
96 Black
p is not near b on the keyboard, so what are you describing in the road?
BTW, lots of torque we got, so it don't take much for the rr to lift around a right curve and make my TC kick in for a split sec. Royal PITA
post #3 of 8 (permalink) Old 01-13-2007, 01:38 PM
bigbusa
i solved that problem quick i shut it off unless its wet out snowing
post #4 of 8 (permalink) Old 01-13-2007, 06:59 PM
Caddylack
TC is even worse in wet weather for me. It makes it so the car will literally not even move if I give it any gas at all. It just cuts the throttle off.
post #5 of 8 (permalink) Old 01-14-2007, 12:56 AM
N0DIH
Is there a PCM tune on it? Maybe the timing retard when TC is engaged is too aggressive.
My factory settings are "Traction Control = OFF" in the switch table, as the ASR does much of the work.
post #6 of 8 (permalink) Old 01-14-2007, 06:36 PM
edy923
I noticed my t/c was really kicking in after I instaled my rear swaybar. I guess it lifts the rear wheel a bit more.
Do you have the same size tires all around? Check all your tire pressures too... I don't know if it wil help much but is the pcm is seeing a different wheel speed, it could be causing your problem...
post #7 of 8 (permalink) Old 01-16-2007, 05:22 PM
Caddylack
YOU CAN PROGRAM TRACTION CONTROL OUT?
I thought you couldn't do this. If you can, that's awesome. I just wish I woulda known before I got my tune. Oh well, I'll have to retune when I get my gears anyway.
post #8 of 8 (permalink) Old 01-17-2007, 03:51 AM
MrCadillac
mine would do this. if it was wet out, I would top out at 55mph unless I turned it off. same size tires all around. one of the rears had more tread(wonder why), but even before this, it was a bitch.
