Might buy a golen engine, need advice. - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 02-19-2007, 06:12 PM
chris joyce
I was considering this engine possibly, does anybody know how good it is and if it's worth it?
http://golenengineservice.com/specs/html/350_360.html
post #2 of 11 (permalink) Old 02-19-2007, 06:25 PM
chris joyce
Sorry guys, this is the engine I was considering.
http://golenengineservice.com/specs/html/383_375.html
post #3 of 11 (permalink) Old 02-19-2007, 06:42 PM
yellowtaws6
Is there anything wrong with your current LT1?
I know there are two guys in the Fleetwood section who are running Golen engines, I am sure they will chime in soon.
post #4 of 11 (permalink) Old 02-19-2007, 06:48 PM
chris joyce
My current LT1 runs pretty strong, but with 108,000 miles it should! I just don't have the time or space to rebuild my current engine or do any major performance mods. I would much rather buy the real deal already profesionaly built and almost ready to plug and play. I would like to have a new engine with my new tranny, that way everythings like new, but a little bit better.
post #5 of 11 (permalink) Old 02-19-2007, 06:52 PM
96capriceMGR
If you are looking for a performance increase that package is the wrong one to look at.
Flywheel HP numbers are MUCH higher than rear wheel.
I would be suprized if you got 290 to the tires with that motor.
post #6 of 11 (permalink) Old 02-19-2007, 07:34 PM
chris joyce
Oh wow!!! Why would it loose that much power from the flywheel to the wheels? That's crazy, thanks for the info man!
post #7 of 11 (permalink) Old 02-19-2007, 07:51 PM
96capriceMGR
It is not just from flywheel to wheels. It is also due to intake restriction, headers that fit a chassis rather than being dyno fixtures, alternator, PS, water pump, exhaust system.
Do a search and the above referenced Fleetwood guy has I think a 440hp package that put like 325 to the wheels. I am not trying to knock Golen just trying to help you understand the realities involved. You want more power order a MUCH higher rated package.
post #8 of 11 (permalink) Old 02-19-2007, 08:31 PM
yellowtaws6
Wow, 108K is just breaking in. I am sure you can get good money for it on the forum or eBay.
Did you check these out:
http://www.karl-ellwein.org/EllweinEnginesHome.htm
post #9 of 11 (permalink) Old 02-19-2007, 08:33 PM
Bad Bowtie
DID SOME ONE SAY PLUG & PLAY!!!!!!!
https://impalassforum.com/noncgi/ulti...c;f=7;t=023900
THE BAD BOWTIE
TUCKER,GA
post #10 of 11 (permalink) Old 02-19-2007, 08:34 PM
Bad Bowtie
THE BAD BOWTIE
TUCKER,GA
