Project craplac daily driver - Chevy Impala SS Forum
post #1 of 21 (permalink) Old 01-08-2015, 03:23 PM Thread Starter
I bought a 95 fleetwood cheap for the super nice black interior for my white car. So I swapped interiors with the blue interior from the white car. It now has a blue interior, black headliner (sunroof so couldn't swap it) and tan radio bezel. It looks great!!
I am the third owner, it has 256k, and runs perfect. It was well maintained. Has some rust issues, but still looks decent. I was gonna resell it, but it runs so good.
So now I am putting my 9c1 axle in. Not for the disc brakes, but for the 3.73s and detroit true trac. Was looking for a torque converter on craigslist, and ended up partial trading for complete trans with s-10 torque converter and trans go shift kit from a member here.
Picking up a complete nos wet kit with throttle body plate this weekend for super cheap. And got a line on a set of hooker shorty headers too.
A friend has a set of drag radials on steel wheels. Gonna see if I can get a low 13 out of this pig??
rpm-inc is offline
post #2 of 21 (permalink) Old 01-09-2015, 04:00 AM
Sweet
I'll be watching.
1995 Cadillac Fleetwood Brougham BBB - Build in progress
Caddylack is offline
post #3 of 21 (permalink) Old 01-09-2015, 07:55 AM
Me -
- too! :d
post #4 of 21 (permalink) Old 03-07-2015, 07:19 AM Thread Starter
A buddy let me use his garage with a lift yesterday. Got the axle and trans in. I had no idea about trans interchange between the years until this morning..... Luckily they are they same years.....
Decided not to do the headers, I just listed them in the classifieds here. Just have to get the exhaust back on and the brake lines done for the discs today. Probably get started on the nitrous kit as well.
rpm-inc is offline
post #5 of 21 (permalink) Old 03-10-2015, 09:31 AM Thread Starter
It hauls ass, lol. Just need to send the pcm out for speedo correction unless I can find someone local.
rpm-inc is offline
post #6 of 21 (permalink) Old 03-11-2015, 04:18 PM Thread Starter
Haven't driven the car much, but it does have a very noticeable scraping sound coming from the rear axle. At first I thought it was just the rust on the rotors. New rotors and pads and its still there. New hardware kit, lubed pins, and h clips are in correctly.
Axle fluid was changed, rtv'd up lube holes cleaned up, and correct felpro gasket installed. I checked for anything rubbing on the driveshaft, and inside the 15" oem wheels.
Sooo.........axle bearings? Anything else to check? The axles are yukon, so hope they are in good shape still. Guess I will do the bearing saver bearings if I have to.
And then the n20 kit!
rpm-inc is offline
post #7 of 21 (permalink) Old 03-12-2015, 03:00 AM
vanaisa's Avatar
Send a message via Skype™ to vanaisa
bearings usually make "humming" sound...
Did you checked brake dust shields - maybe they are bent?
vanaisa is offline
post #8 of 21 (permalink) Old 03-12-2015, 04:57 AM Thread Starter
There are no brake shields. It is definitely a metal on metal sound. It sounds like a pad with no material left. Most noticeable at low speeds. I'm sure its still there at higher speeds, just cant hear it over the road noise.
rpm-inc is offline
post #9 of 21 (permalink) Old 03-12-2015, 01:49 PM
vanaisa's Avatar
Raise rear end and spin wheels by hand. This way you locate source.
vanaisa is offline
post #10 of 21 (permalink) Old 03-12-2015, 02:00 PM Thread Starter
Yeah thats next. It hasnt been in the air again since I did brakes. I did spin them slowly after brakes were done and didn't hear anything, so thought it was fixed. I will prob get it in the air and put it in gear with somebody in the seat keeping the speed down. I don't think I am going to find anything, though.
rpm-inc is offline
