New Fleetwood Owner! Few D-body questions. - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 11-07-2016, 06:31 PM Thread Starter
95Chwagon's Avatar
I have completed the collection with a triple black 96 Fleetwood. 76k, clean, straight and well documented. I have a hoard of B-Body parts and would like to know of anyone knows what is interchangable.
This is going to be my truck. I had a friend setup a 9c1 diff with 4.10s and a posi. I know that is the same width as the D-body, but what do I need to retain ABS? Just swap over the drums and ABS hardware?
Also wondering what hitch fit the Fleetwoods. Is it the same as a sedan or wagon or is it its own design? Does anybody run a brake controller towing 7k?
Body is mint besides a ding in the driver fender and the chrome strips on the quarters and fenders. Does anybody have a clean set they are willing to sell? Or is anybody on here running the aftermarket stainless ones Ive seen on lowrider forums?
Lastly, since I would like to tow with this using the stock LT1 for the time being, what have others done to do a V4P conversion? I already have the oil/trans coolers, FE2 suspension and plan on a gear and posi. Is a TransGo-HD2 worth the effort? I was planning on dropping the temp so the secondary fan kicks on earlier and then I don't need to convert to mechanical. New AC delco shocks are going on front and rear (rears are leaking air). I would like to keep everything as stock as possible for the time being since everything works.
Thanks for any tips. This is my 5th operable 92-96 B/D body and I must say it is the nicest.
95Chwagon is offline
post #2 of 9 (permalink) Old 11-07-2016, 07:39 PM
The Stickman's Avatar
Ok I am going to take a guess here and say that you bought a hearse. The part about using it as a truck and triple black, which tends to be a limo package make me think that. If you do have a hearse then there can be a lot of none standard parts on your car. Let me know if I am correct or not.
Neil P.
1996 Federal hearse. CAI, Delphi 3.5 MAF, Aluminum elbow, airfoil, coolant bypass mod, 36lbs injectors, LE 223/231 110 LSA cam, Trickflow pushrods, Comp Cams rocker studs, Lunati 1.6 roller rockers,double spring kit and lifters, F-body heads, Cometic MLS .027 head gasket, Hooker headers, Cloyes timing chain, PowerBond balancer, EGR, air pump and AC delete. Solomon tune. CPT Pro-Race trans, 9.5 inch 3200 stall converter, 9.5 inch 14 bolt rear, 4.10 gear and TruTrac helix gear diff
The Stickman is offline
post #3 of 9 (permalink) Old 11-07-2016, 08:53 PM Thread Starter
95Chwagon's Avatar
Guess I left that part out. Its been a long day.
No its a sedan. Would love to pull a trailer with it. Here she is.
post #4 of 9 (permalink) Old 11-08-2016, 04:43 PM
Don't try - it just won't work. Completely DIFFERENT ABS systems between the B- and D-body. Search will explain all.
Regular B-body sedan will fit.
While of course not the same as all the internal work of a Trans-Go, considering your low miles you can get programming done quite easy to increase line pressures-shift points-lowered fan temps.
Most all B- suspension will fit under a D-.
post #5 of 9 (permalink) Old 11-08-2016, 04:47 PM Thread Starter
95Chwagon's Avatar
Thanks for the reply.
I know B-body is 3 channel and D-body is 4. I figured since the housing is the same the swap would have been done by now. I would like to swap over the 4 channel pieces (whatever they are) to the built 9C1 diff.
post #6 of 9 (permalink) Old 11-09-2016, 08:35 AM
dauderm1's Avatar
The Cadillac 4-channel system uses two wheel sensors and unique axles with tone rings. You can just swap the backing plates(w/sensors), axles, and brake lines from your Fleetwood to the 9C1 diff. You'll have to plug the hole or leave the sensor in the 9C1 Housing.
If you had an Impala/Caprice rear, the axles wouldn't be interchangeable due to the longer length housing.
dauderm1 is offline
post #7 of 9 (permalink) Old 11-09-2016, 08:28 PM Thread Starter
95Chwagon's Avatar
Awesome that was what I was hoping for since the diff is already set up. Thanks for the reply!
post #8 of 9 (permalink) Old 12-29-2016, 01:00 PM Thread Starter
95Chwagon's Avatar
Last question on the ABS. It is a 2.93 peg leg now. Do I need different axles/sensors with a gear swap to say 3.73? Or can it all be programmed?
96 Caddy, Triple Black/Grandpa Fresh
95 Cappy, Retired California Cop BBHP-120
92 RMW, Layin Wood on Billet Boyds
95 Chwagon R.I.P.
post #9 of 9 (permalink) Old 12-30-2016, 08:09 AM
dauderm1's Avatar
Your current abs system will work, check out this thread...
https://www.impalassforum.com/vBullet...-question.html
dauderm1 is offline
