94 Fleetwood Fuel Pump Replacement - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 01-12-2017, 12:09 PM Thread Starter
I've been presented with a possible deal on a spare fuel pump for the 94 Fleetwood I'm working on. How much of a pain in the arse is it to change the fuel pump out off the fuel pump hanger assembly on this car? Didn't see anything in search. Thanks!
Working on a 1994 Cadillac Fleetwood Brougham...
CB700S is offline
post #2 of 11 (permalink) Old 01-12-2017, 01:05 PM
Not a Caddy Guy but the sending unit looks the same as the Caprice/Impala.
https://www.summitracing.com/parts/s...odel/fleetwood
So removal of the FP from the Sending unit should be exactly the same and should be able to follow most FP replace instructions here. Be sure to check the "Refurb" thread as well while it is removed.
But to answer your question, Once the entire assembly is removed from the tank, Remove the Filter Sock from the bottom of the pump, then remove the Plastic Lid from the top of the pump. It just has 4 plastic locking tabs. then the Pump itslef should pull right out of the housing.
BE SURE to evaluate the internal wiring very well. I think most FP related issues are due to bad intank wiring/connections.
post #3 of 11 (permalink) Old 01-12-2017, 05:36 PM
Make sure you are getting a good brand of pump. There are some bad manufacturers of pumps for these cars. Let someone on here know what brand it is before you install it.
post #4 of 11 (permalink) Old 01-12-2017, 11:14 PM Thread Starter
It's a Bosch turbine pump - I've had good luck with those in the past on other cars. Are there issues with those on these vehicles?
CB700S is offline
post #5 of 11 (permalink) Old 01-13-2017, 07:03 AM
I have a 92 OCC, The pump is a little different on it, but I have not had any good things to say about Bosch. I put one in about 7 years ago, and it lasted a month. I replaced it for free, and that one lasted a year and a half. I have since put an AC Delco., or Delphi pump in it, and it is still there.
post #6 of 11 (permalink) Old 01-13-2017, 07:23 AM Thread Starter
It was on sale at Amazon for about $25 and we already pulled the trigger on it. -shrug- Had good luck with Bosch turbine pumps in other vehicles, so that's the type we got. Their old style pumps, not so much.
CB700S is offline
post #7 of 11 (permalink) Old 01-13-2017, 07:35 AM
Why do you think it was on sale do cheap on Amazon?
post #8 of 11 (permalink) Old 01-13-2017, 07:47 AM Thread Starter
Amazon Warehouse Deals - unused returned items or items with damaged packaging at huge discounts. We picked up a bunch of North American made Delco parts for the car for up to 80% off - should we also consider these crap for the same reason? :P
CB700S is offline
post #9 of 11 (permalink) Old 01-13-2017, 08:03 AM
The AC Delco parts are probably good. Other brands may or may not be as good as OEM.
post #10 of 11 (permalink) Old 01-13-2017, 09:54 AM
From my experience and what I've read based on others experience, I would only trust 2 brands....Delco and Walbro. Having done the "tank Drop" dance more times than I care to remember, using a inexpensive Fuel Pump based on the cost alone is not a good way to evaluate your choices. Also, do your research on where you purchase from. I know Delco has some counterfeit parts out there that can look legit and even Walbro recommends on their website that you buy only directly from them since there are also knock-offs of their pumps going on and sold on sites like Ebay.
I used to recommend Racetronix Pumps but they switched over from Walbro to their own brand (Turbine-tech) and I find them to be....jury is still out on mine as it still works but another member had one literally burn up and melt. They do offer some other very nice Fuel System products for our car (wiring kits) but their Customer Service is NOT great and difficult to deal with.
But if money is the primary reason for the call, then only you can decide that and just be aware it could cost you more money in the long run....break down while away from home, Towing costs, aggravation (what's that worth?) and just an overall PITA to do again.
Whatever you choose to install, just be sure to thoroughly and closely inspect the In tank wiring and Connections. I know I mentioned this before, but I cant emphasize this enough. Good Luck with your repairs.
