Sadly parting out my 96 Fleetwood. Anyone need anything that can ship? - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 10-23-2017, 05:11 PM Thread Starter
After realizing my underbody was compromised of rust and I developed a massive knock in my engine, Ive decided it's time to put down my black 96 fwb.
I already pulled the grill, headlights, signal lights, keyless entry module, all chrome side panels, headlight trim, tail lights, deck, interior door panels/switches, rear speakers, door speakers.
Let me know if anyone needs anything that can be shipped.
durrk johnson is offline
post #2 of 13 (permalink) Old 10-23-2017, 05:34 PM
Another cool mod for any b-body is the under carpet AC/heat floor ducts for the rear seat area. It should include the 2 legs and the manifold fitting they slip onto.
You may want to list them up too if it has them. GLWS's.
post #3 of 13 (permalink) Old 10-23-2017, 07:19 PM
I was going to ask about the exact same thing...
post #4 of 13 (permalink) Old 10-23-2017, 08:15 PM Thread Starter
What is this you guys are talk about. Got pics? Not familiar with it. It's a 96 Fleetwood Brougham
post #5 of 13 (permalink) Old 10-23-2017, 08:39 PM
Here you go...post #16 has pics...
https://www.impalassforum.com/vBullet...r-c-ducts.html
post #6 of 13 (permalink) Old 10-23-2017, 09:45 PM Thread Starter
Oh wow. So those are under the carpet? Are they difficult to remove?
post #7 of 13 (permalink) Old 10-24-2017, 06:29 AM
Yes and No.
Yes - the "Frog Leg" pieces run under the Carpet from the Manifold, along the Trans Tunnel and then under the Seats.
No - for the Most part the "Frog Legs" just Lay there and are only secured at the very end with a Plastic Push Pin. It should be obvious once you lift the carpet. I think there is 1 Screw that holds the Manifold piece on too.
post #8 of 13 (permalink) Old 10-30-2017, 06:47 PM
fuzzcar's Avatar
Where are you located? Does it have gold or chrome emblems? I may be interested in some pieces.
fuzzcar is offline
post #9 of 13 (permalink) Old 10-31-2017, 09:58 PM Thread Starter
Hi. It has the gold but they aren't the best of shape. I'm in Milwaukee
post #10 of 13 (permalink) Old 11-01-2017, 08:01 AM
juniorwatson's Avatar
Can you tell me if you have this bezel in good condition?
BEZEL
juniorwatson is offline
