Hearse doors? - Chevy Impala SS Forum
 1Likes
  • 1 Post By 95wagon
post #1 of 7 (permalink) Old 04-28-2018, 11:24 AM Thread Starter
schlicky13's Avatar
Hearse doors?
Every now and then I look around the interwebs for later ('95-'96) style doors with the updated mirrors, and I actually came across a good pair in the same color. Except they're on a hearse. Anybody know if the doors are still exactly the same? Or was anything different about them that wouldn't work? I've been in touch with the guy that has them, and almost have everything lined up to pull the trigger on them, but wanted to be sure I won't run into any weird issues coming from a commercial chassis car.
Something witty.
schlicky13 is offline
post #2 of 7 (permalink) Old 04-28-2018, 04:54 PM
95wagon's Avatar
9BQ is the hearse prep option.
It shows up in the parts book where there are differences.
In the door section, the is no "with or "except" 9BQ
I should add this is from the B body book, not a "D"
schlicky13 likes this.
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
post #3 of 7 (permalink) Old 04-29-2018, 12:07 AM Thread Starter
schlicky13's Avatar
They looked identical in the all the pictures, except the interior panels are a different color, so I'll just swap mine on. I have to deal with freight shipping to get them, so I have to figure that out, but I think I'll go ahead and get them and cross that mod off my list.
Something witty.
post #4 of 7 (permalink) Old 04-29-2018, 12:27 PM
There are a few difference Fleetwood hearse conversions in the wild. You would need to make sure the doors are off of one of the conversions that retains the curved window frame. Some straighten it out.
threeimpalas is offline
post #5 of 7 (permalink) Old 04-29-2018, 08:51 PM
If you are putting the doors in a Caprice, they will have holes in them for the stainless trim retainers. You will be fixing the holes to use them on the Caprice. The doors from a Caprice will not have the holes. If you are putting them on a Fleetwood you should be good to go. For a Caprice you will also have to remove the top interior mounts, and install the arm rest support. The nylon "nuts" for the pull strap may be placed differently too.
There is a nice Caprice driver's side door in the local yard here in FL.
post #6 of 7 (permalink) Old 05-03-2018, 12:47 AM
The Stickman's Avatar
You have to be careful. hearses are made by coach builders and each do things differently. The 94-96 Superior hearses have a commercial windshield, but not like they used to do in making it taller. They actually leaned the A pillars out so that the top of the windshield is 6 inches wider at the top. So I would be the door have been tweaked as well. If it is a Federal like mine the front doors are stock Cadillac items.
Neil P.
1996 Federal hearse. CAI, Delphi 3.5 MAF, Aluminum elbow, airfoil, coolant bypass mod, 36lbs injectors, LE 223/231 110 LSA cam, Trickflow pushrods, Comp Cams rocker studs, Lunati 1.6 roller rockers,double spring kit and lifters, F-body heads, Cometic MLS .027 head gasket, Hooker headers, Cloyes timing chain, PowerBond balancer, EGR, air pump and AC delete. Solomon tune. CPT Pro-Race trans, 9.5 inch 3200 stall converter, 9.5 inch 14 bolt rear, 4.10 gear and TruTrac helix gear diff
The Stickman is offline
post #7 of 7 (permalink) Old 05-03-2018, 12:50 AM
There is a problem with hearses and RPO codes. The damn stickers are no where to be found. The sticker is supposed to be under the trunk lid. And Commercial Chassis do not have trunk lids. I have looked all over mine and other peoples cars.
Neil P.
