A day at the dyno - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 05-07-2018, 03:37 PM Thread Starter
The Stickman's Avatar
A day at the dyno
well yesterday I attended a local dyno day and came away very pleased. The car wasn't perfect as it kept shifting on the dyno which messed up the torque readings. But the car posted a reading of 295hp so I will take that and run with it. Now the engine can come out for more work to begin. Can't wait to see what I can get out of it.
Neil P.
1996 Federal hearse. CAI, Delphi 3.5 MAF, Aluminum elbow, airfoil, coolant bypass mod, 36lbs injectors, LE 223/231 110 LSA cam, Trickflow pushrods, Comp Cams rocker studs, Lunati 1.6 roller rockers,double spring kit and lifters, F-body heads, Cometic MLS .027 head gasket, Hooker headers, Cloyes timing chain, PowerBond balancer, EGR, air pump and AC delete. Solomon tune. CPT Pro-Race trans, 9.5 inch 3200 stall converter, 9.5 inch 14 bolt rear, 4.10 gear and TruTrac helix gear diff
The Stickman is offline
post #2 of 7 (permalink) Old 05-09-2018, 12:18 AM
TGO
Care to share your mods or?
2001 Corvette ZO6
1995 Impala SS - H/C/I - BBB
TGO is offline
post #3 of 7 (permalink) Old 05-14-2018, 10:48 PM Thread Starter
It has a CAI(filter, straight tube, aluminum elbow, airfoil, coolant bypass mod, Hooker Super Competition headers, small glass packs and 4.10 gears and a Tru Trac diff all with a tune om the PCM. Don't think I am leaving anything out. Really didn't think it would make that much. I will be taking the car to my engine builder tomorrow.
Neil P.
post #4 of 7 (permalink) Old 05-15-2018, 06:29 AM
Blue Wail's Avatar
Thats a lot of power on a reliable motor to tear it down.
If the mileage is under 100k on the motor, I'd keep it as a spare and get
another block to build up. You can find LT1 engines used on Craigs or your
local yard for around $300.
An added bonus of this idea, is less down time/ pushing the car around while
the engine is out.
Nab
April's Sparkle Cat
383 LT1 12:1 flat top + 75 shot
11.66 @ 117 at SSHS17 Nov 11, 2017
2017 12.0 Index Champion
4140 lbs. w/ driver. front sway bar ON
Powered by 4L80E! (controlled by LT1 pcm)
Blue Wail is offline
post #5 of 7 (permalink) Old 05-15-2018, 10:16 PM Thread Starter
the engine is out.
Nab
Already at my engine builder. Dropped the car off today.
Neil P.
post #6 of 7 (permalink) Old 05-16-2018, 05:18 AM
juniorwatson's Avatar
What mileage on the current engine? Like Blue Wail wrote, those are great numbers for what ya got.
I've always been curious about mine, as she still does very well @ 181,000 but it's time to get the other engine completed and installed.
juniorwatson is offline
post #7 of 7 (permalink) Old 05-16-2018, 10:17 PM Thread Starter
No idea. The previous owner put new gauges in and I don't remember how many miles he said were on it at that time. I have put like 14K miles on it since owning it.
Neil P.
