Axle specs/dimensions - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 07-18-2018, 01:46 PM Thread Starter
I've been scouring the forum and the web and can't find the Fleetwood 94-96 standard 8.5" ring gear axle dimensions. Moser tells me they need specs and/or the old one, but we're still driving the car in town as needed, so I'd rather not pull the axle until I have a good idea I'll get one - I'll be in trouble if the car is disabled in the garage long. So, anyone have the measurements I'll need? I realize the ABS reluctor (?) will need to be moved and they'll likely need to fab a way to mount it. I've found specs for the B-body axles, but the Fleetwood was different, at least for the ABS.
Missing my Fleetwood. Working on my '95 RMS, but hoping to find a wagon. Every kid should experience sitting in that rear-facing seat. I have three deprived kids.
beengone is offline
post #2 of 11 (permalink) Old 07-18-2018, 09:39 PM
Z09B4U's Avatar
I know nothing about:
Tom's Differentials - Home of MADE IN THE U.S.A.
But in the catalog (pg144) it lists:
93-94 Fleetwood Brougham w/8.5 rear drum and anti lock
30 sp. 30 1/2" Factory#26028502 K.A #CAD-5
So it looks like this is a stock item that does not have to be custom made.
You could use the factory# on a Cadillac forum and see what turns up.
Z09B4U
Z09B4U is offline
post #3 of 11 (permalink) Old 08-04-2018, 08:52 PM Thread Starter
Thanks. I have a guy buying it this coming week and he thinks he found an axle. If not I’ll try that. It’s odd that it’s listed as a 93-94, that makes me wonder.
beengone is offline
post #4 of 11 (permalink) Old 08-04-2018, 09:02 PM
gbhs72's Avatar
Does this help you out? Hope so. https://www.impalassforum.com/vBulle...nd-widths.html According to this it's the same as my 9C1 rear.
Mark: Snowman-33
gbhs72 is offline
post #5 of 11 (permalink) Old 08-05-2018, 10:08 AM
Z09B4U's Avatar
Itís odd that itís listed as a 93-94, that makes me wonder.
beengone
It should be 93-96 but you can ask him. He also lists the heavy limo axel as being non anti lock so most of the info seems correct.
. gbhs72
Same length and spline count yes, But the Fleetwood needs mounting points for the reluctors.(4 channel ABS)
Z09B4U
Z09B4U is offline
post #6 of 11 (permalink) Old 08-07-2018, 01:54 AM
The Stickman's Avatar
Originally Posted by Z09B4U View Post
beengone
. gbhs72
The heavy limo which should be actually a commercial chassis axle is the 9.5 inch 14 bolt which is not only ABS delete but also traction control delete. Axle ratio is 3.63 or 3.66 I forget which
Neil P.
1996 Federal hearse. CAI, Delphi 3.5 MAF, Aluminum elbow, airfoil, coolant bypass mod, 36lbs injectors, LE 223/231 110 LSA cam, Trickflow pushrods, Comp Cams rocker studs, Lunati 1.6 roller rockers,double spring kit and lifters, F-body heads, Cometic MLS .027 head gasket, Hooker headers, Cloyes timing chain, PowerBond balancer, EGR, air pump and AC delete. Solomon tune. CPT Pro-Race trans, 9.5 inch 3200 stall converter, 9.5 inch 14 bolt rear, 4.10 gear and TruTrac helix gear diff
The Stickman is offline
post #7 of 11 (permalink) Old 08-11-2018, 01:29 PM
There is a FW in the local yard right now. The left axle is usually in better condition than the right. If interested LMK.
post #8 of 11 (permalink) Old 08-15-2018, 08:22 AM Thread Starter
Thanks. Supposedly I have a guy coming to buy it and he's shipping an axle to replace it when he gets here. If that falls through, any idea on cost for one or both? Shipping would be to 49631.
beengone is offline
post #9 of 11 (permalink) Old 08-15-2018, 08:24 AM Thread Starter
BTW, what color ext/int? If white ext. and burgundy int, he may want some small parts (passenger mirror if 94-96, center console).
beengone is offline
post #10 of 11 (permalink) Old 08-15-2018, 08:41 AM
Black exterior, tan interior.
The axles would be about $75 each plus shipping. I would have to pack it/them to get a price. Moser charged me $43 to ship my wagon axles, but they get some kind of a "frequent flyer" discount.
The 94 has the 91-94 B body mirrors. The one in the yard is a 94.
