Seat Broke/Collapsed - What's This Part? - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 09-20-2018, 03:17 AM Thread Starter
While the Fleetwood was being inspected this year, the driver's seat popped and the rear left corner hit the floor. This part came rolling out from underneath:
IMG_5398
IMG_5399
IMG_5400
IMG_5401
The seat seems to be disconnected from anything on that rear corner now. As it's been hot and sticky or raining hard (nothing in between) around here lately, I've not had a chance to pull the seat out and find out what went wrong. Anyone have any ideas - what this thing is, what it does, how do I fix it? It kind of looks like a pin that gets secured with a C/E-clip or snap ring and gets used as a pivot of some kind. Thanks.
Working on a 1994 Cadillac Fleetwood Brougham...
CB700S is offline
post #2 of 5 (permalink) Old 09-20-2018, 07:20 AM
silverfox103's Avatar
Send a message via AIM to silverfox103
Never had my Fleetwood seats apart, but on Roadmaster wagons there is a bolt with a shoulder on it that breaks, at the hinge area where the bottom and back of the seat connect. I would pull out the driver seat, peel back the material and look at the hinge area. Look on the side that didn't break as there should be an identical piece. Like you said, it does look like it had a clip or retainer on it. If that's the case it should be an easy fix.
Tom
1994 RMW LAB---my toy from FL 156,000
1994 Caprice Wagon---never seen winter 105,000
1996 Cadillac Fleetwood---never seen winter 65,000
silverfox103 is offline
post #3 of 5 (permalink) Old 10-02-2018, 09:04 PM Thread Starter
It turns out that the part that rolled out appears to have been something used as filler in a bad repair job for the left rear seat rail leg.
IMG_5913
IMG_5911
CB700S is offline
post #4 of 5 (permalink) Old 10-26-2018, 03:48 AM Thread Starter
Final followup: Upon further investigation, I found that the round thing was not used as a welded-in spacer but was a pivot point in the seat raise/lower mechanism that had had the "push nut" clip crack and fall off due to the uneven stress placed on the assembly by the broken leg. The pivot eventually fell out of the assembly as well. Fortunately, a push nut can be had for $3 from pretty much any parts store out of the Help! section in an assortment pack.
Next, it turned out that the leg had simply cracked in half and all parts were still in the car. It appears that this had happened before and been inexpertly welded (note the booger-like welding in the pictures above) but then it cracked again at a different point midway down the leg instead of at the top where it had before. I took the seat and leg fragments to a professional welder of my acquaintance and he was able to not only properly weld the leg back together but reinforce it so this hopefully doesn't happen again.
Mid-welding:
IMG_6485
After welding but after first paint shot:
IMG_6492
IMG_6493
Wish GM had painted all these raw steel pieces on the bottom of the seat, they're all rusty now. Anyway, we bolted the seat back into the car and it seems fine now.
CB700S is offline
post #5 of 5 (permalink) Old 10-26-2018, 06:52 AM
Thanks for checking in
Wow. Snapped that leg clean off. Raise hands everyone immediately jumped to wondering what 2 people had to be doing on that seat for that to happen. ::smiles::
