Two different Spectra senders for Fleetwood - Page 2 - Chevy Impala SS Forum
 1Likes
post #11 of 13 (permalink) Old 03-25-2019, 01:21 PM Thread Starter
Originally Posted by Sinister View Post
Simple. One of them has a pump (Fuel pump and Housing) and the other (Fuel sending unit) doesn't. They are listed the same way for the Caprice.
I bought the cheaper one and it came with a fuel pump.
Sinister likes this.
1995 Cadillac Fleetwood Brougham BBB - Build in progress
Caddylack is offline
post #12 of 13 (permalink) Old 04-08-2019, 11:10 PM
HUF
HUF's Avatar
Spectra fuel pump gets a lot of negative reviews. Nevertheless, in most cases the old wiring could be the real culprit.
Question: anybody having a bad experience with THE PUMP & HOUSING ASSEMBLY (not just the pump)?
In the picture you can see the original ACDelco pump I had to replace with Spectra. The burnt plastic housing is around negative contact. The new Spectra pump (or maybe the old wiring) is a suspect for recent no start condition after only 7 months 1,400 miles.
There’s nothing as permanent as a temporary solution.
1995 Cadillac Fleetwood Brougham 122,XXX miles.
HUF is offline
post #13 of 13 (permalink) Old 04-09-2019, 06:27 AM
As offered in your related thread, I never had issue with my Spectra replacement in my old FWB. I did however install a new harness, where the problem more likely lies as you say if reusing the original.
96 Black is online now
Similar Threads
Spectra Cold air intake on a Fleetwood KDB50SS Fleetwood 0 04-27-2017 06:58 PM
Alternate Oil Pressure Senders Sshockr Engine Problems/Maintenance 3 04-12-2011 10:39 AM
Gauges and Senders C5Shark Interior 2 07-13-2006 02:21 AM
Oil and Fuel Pressure Senders TenaciousDB Electrical 0 11-07-2003 10:26 AM
Elec temp gauge senders--interchangable?? Baatfam Electrical 2 04-15-2002 11:51 AM
