Two different Spectra senders for Fleetwood - Chevy Impala SS Forum
 1Likes
post #1 of 13 (permalink) Old 03-08-2019, 07:47 PM Thread Starter
While browsing RockAuto, I realized that there appear to be two different senders listed for the 94-96 Fleetwood. Part # FG128C under "Fuel Sending Unit" costs $116. Then, under "Fuel Pump & Housing Assembly", part # SP128C1H is listed for only $78. The pictures look identical.
What is the difference?
1995 Cadillac Fleetwood Brougham BBB - Build in progress
Caddylack is offline
post #2 of 13 (permalink) Old 03-09-2019, 11:56 AM
SSandman's Avatar
I'm not seeing the other part number listed anywhere for a B/D body (on rock auto anyway). I tried 94, 95, 96 fleetwood and 96 impala SS and the only part number Rock Auto showed me for Spectre is the SP128 one. If you look at amazon, the dimensional specs for the two pumps is completely different. Not really sure though, other than calling Spectre direct, but if it helps at all I just ordered n SP128C1H for my 96 Impala SS. lol
SSandman is offline
post #3 of 13 (permalink) Old 03-09-2019, 12:12 PM Thread Starter
I just checked again, and I am still seeing both numbers listed for my 95 Fleetwood. Both part numbers list 94-96 Fleetwood exclusively and no other makes or models.
post #4 of 13 (permalink) Old 03-09-2019, 02:45 PM
Z09B4U's Avatar
SSandman
I searched both part# this morning and only one showed. BUT:
Caddylack
I rechecked both just now and they are both 94-96 Fleetwood exclusively and no other makes or models.
Bottom line do not trust RockAuto. Get Spectra or a dealer to verify parts description. I may post RockAuto's customer service responses to a inquiry I just made as to why they list a part that a manufacturer does not admit exists , and in fact recommends a different part for my application.
Z09B4U
Z09B4U is offline
post #5 of 13 (permalink) Old 03-09-2019, 07:06 PM Thread Starter
Also, SSandman... are you sure you bought SP128C1H and not SP128B1H? The latter is the number for the Impala unit.
post #6 of 13 (permalink) Old 03-12-2019, 10:55 AM
SP128B1H: B-body
SP128C1H: D-body (Caddy only)
The only difference that I am aware of is the extra length of the metal sending unit pipes for the D-body application. I suspect the D-body one would work on the B-body but the B-body one may not work on the D-body unless you can get the fuel lines to reach without stress.
-- Tom
2011 Caprice PPV
1995 Impala SS
1994 Caprice 9C1 LT1
1995 Caprice 9C1 LT1
1995 Caprice Wagon
1972 Chrysler Newport 2-door
1969 C30 Flatbed
1969 Dodge Charger
storm9c1 is offline
post #7 of 13 (permalink) Old 03-12-2019, 01:48 PM Thread Starter
Originally Posted by storm9c1 View Post
SP128B1H: B-body
The d-body sender has 4 wires, whereas the b-body unit has 3. I would assume the extra wire is related to the digital gauge.
post #8 of 13 (permalink) Old 03-14-2019, 11:02 AM
Oh yeah, that would be a big detail for me to forget! Sorry. That's correct... the Caddy sending unit does not share the fuel pump ground in the tank. It has a separate wire, which accounts for the 4th wire.
Now if someone were in a bind on a b-body, they could rewire it by cutting off the plug from the old harness, wiring it in, and connecting one of the sender wires to the ground wire. But I'm not recommending this at all! Just buy the correct sender. Rewiring it the other way around (adapting a b-body to a d-body wiring) would be harder but perhaps not impossible.
-- Tom
2011 Caprice PPV
1995 Impala SS
1995 Caprice Wagon
1969 C30 Flatbed
1969 Dodge Charger
storm9c1 is offline
post #9 of 13 (permalink) Old 03-17-2019, 11:32 AM
SSandman's Avatar
THIS! Sorry about that, grabbed the wrong part number. The SP128B1H is what I purchased.
SSandman is offline
post #10 of 13 (permalink) Old 03-17-2019, 11:49 AM
Sinister's Avatar
Simple. One of them has a pump (Fuel pump and Housing) and the other (Fuel sending unit) doesn't. They are listed the same way for the Caprice.
1995 Caprice Wagon
Sinister is offline
Similar Threads
Spectra Cold air intake on a Fleetwood KDB50SS Fleetwood 0 04-27-2017 06:58 PM
Alternate Oil Pressure Senders Sshockr Engine Problems/Maintenance 3 04-12-2011 10:39 AM
Gauges and Senders C5Shark Interior 2 07-13-2006 02:21 AM
Oil and Fuel Pressure Senders TenaciousDB Electrical 0 11-07-2003 10:26 AM
Elec temp gauge senders--interchangable?? Baatfam Electrical 2 04-15-2002 11:51 AM
