Pre-formed stainless brake lines? - Chevy Impala SS Forum
 3Likes
  • 1 Post By silverfox103
  • 1 Post By gbhs72
  • 1 Post By Navy Lifer
post #1 of 9 (permalink) Old 05-08-2019, 08:07 PM Thread Starter
schlicky13's Avatar
Stumbled on this while perusing ebay for Fleetwood related brake stuff, (I swear Goodridge used to make a stainless braided kit for it a few years back and someone on here has been looking for a kit, but so far I think I just hallucinated that they existed). Anyways, thought it was interesting and possibly useful to someone. I also found it odd that it only lists '95-96 Fleetwoods? Is there some significant difference in the brakes for the '93-94 Fleetwoods.
https://www.ebay.com/itm/1995-1996-C...oAAOSwnFFaoY48
And they also appear to have the rear hard lines for all years.
https://www.ebay.com/itm/1994-1996-C...YAAOSwnCxaoY52
Edit: OK, I think they actually have all possible hard lines, I'll just include a link to the Fleetwood brake line search I just did in their store.
https://www.ebay.com/sch/m.html?_ssn...twood&_sacat=0
Something witty.
schlicky13 is offline
post #2 of 9 (permalink) Old 05-08-2019, 08:12 PM Thread Starter
schlicky13's Avatar
I also just noticed that a bunch of the rear listings are for disc brakes, I assume for people who've done conversions? Interesting.
Something witty.
post #3 of 9 (permalink) Old 05-09-2019, 04:39 AM
silverfox103's Avatar
Send a message via AIM to silverfox103
Nice Find!!
thanks
Tom
schlicky13 likes this.
1994 RMW LAB---my toy from FL 156,000
1994 Caprice Wagon---never seen winter 105,000
1996 Cadillac Fleetwood---never seen winter 65,000
silverfox103 is offline
post #4 of 9 (permalink) Old 05-09-2019, 06:32 AM
gbhs72's Avatar
X1 Thanks
Mark: Snowman-33
gbhs72 is online now
post #5 of 9 (permalink) Old 05-12-2019, 11:42 PM
Navy Lifer's Avatar
I would be very cautious when it comes to the Fleetwood--the last FW chassis had 4-wheel ABS, and 2 hoses ran from the frame to the rear axle to independently control the rear wheels during ABS activation.
The photos in the links showing FW axle hard lines for disc brakes are NOT for 4-channel ABS--what is shown is made to meet in a tee fitting, same as B-body 3-channel ABS, and will not work. The inner end of the right & left hard lines for the disc conversion kit I have offered are bent to correctly meet at the top of the diff housing to align with a bracket as used in the production (drum) brake configuration, with the OE rear disc from B-body piping shape at the outer end.
The hard lines in the ebay ad are from Inline Tube, a Detroit area supplier. I've worked with them in the past, but do not recall whether they made the FW conversion lines for me, or if it was Classic Tube....it's been awhile.
Updated with photos showing the difference in the axle hard lines for Fleetwood (4-channel ABS) conversion vs the standard (3-channel ABS) hard lines as used on B-body.
First photo - Upper lines for Fleetwood show the bends to meet the bracket to connect to the hoses going to the frame--left line uses the 12mm (green) ferrule fitting. Lower lines are for the standard tee junction on B-body.
Second photo - Classic Tube part numbers for the Impala SS & Caprice 9C1 (with rear disc) hard lines - SS in the PN means stainless steel material
Bill Harper
ISSCA #127
[email protected]
Navy Lifer is offline
post #6 of 9 (permalink) Old 05-13-2019, 07:34 AM
Bill, digging into distinctions B- rear hose v. D- rear hose(s) going on here:
https://www.impalassforum.com/vBulle...ake-hoses.html
Orientation you describe shown Post 24. I'm hunting for s.s. braided for the rears and so far succeeding in not finding any. ::frown::
post #7 of 9 (permalink) Old 05-13-2019, 08:45 AM
Navy Lifer's Avatar
responded in the other thread.....should be doable, suggest you provide an OE sample for the supplier to duplicate in braided stainless
Bill Harper
ISSCA #127
[email protected]
post #8 of 9 (permalink) Old 05-13-2019, 09:10 AM
Check, and good intel on the two hoses being swapped end-for-end to keep from connecting to the opposite sides. I bet that would lead to pretty strange operation!
post #9 of 9 (permalink) Old 05-13-2019, 10:55 PM
Navy Lifer's Avatar
added photos & text to post #5
Bill Harper
ISSCA #127
[email protected]
Similar Threads
"Newly formed interior pond" Deputy347K9 Interior 9 09-29-2016 03:59 PM
Brake lines - hard lines not flex lines Clear Image Auto (Dan) Vendor Area 28 06-09-2015 05:11 PM
Stainless steel brake lines? jerseykid96 Brakes 7 03-12-2008 11:47 PM
Stainless steel brake lines MR SGF Brakes 8 01-18-2008 09:02 AM
Cold Formed vs Heat Treated Sway Bars Bob Lane Suspension 4 02-20-2007 12:27 PM
