1995 fleetwood idling issue - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 07-06-2012, 02:53 PM Thread Starter
ENVIUS's Avatar
When i first start the car it idles real rough and you can here it sucking air...if i give it some gas and hold it to higher RPM a few seconds i can let of the gas and it idles fine...it runs and drives fine after that....it almost starts up like a cold carburetor motor. This is after replacing opti, opti harness, cap, rotor, coil, plugs, wires, MAP sensor, and MAF sensor wire harness and pigtail. The only other thing i can think would be maybe the Mass Airflow Sensor. I am not familiar how the engine should run with this sensor being bad.
Any suggestions?
ENVIUS is offline
post #2 of 8 (permalink) Old 07-07-2012, 09:36 AM
CustomCaddys's Avatar
Send a message via AIM to CustomCaddys
is the check engine light on?
/ Will
Daily - Inferno 06 SRT8 Jeep.. 12.1 @ 112
http://www.youtube.com/watch?v=36zLd_fRRxs
Summer Sleeper - murdered 95 FWB..
http://www.youtube.com/watch?v=MYiFJE_2Q2w
CustomCaddys is offline
post #3 of 8 (permalink) Old 07-07-2012, 10:31 AM Thread Starter
ENVIUS's Avatar
yes it is on and goes away after driving it sometimes
ENVIUS is offline
post #4 of 8 (permalink) Old 07-07-2012, 11:35 AM Thread Starter
ENVIUS's Avatar
heres a video i took of it running....
ENVIUS is offline
post #5 of 8 (permalink) Old 07-07-2012, 12:26 PM Thread Starter
ENVIUS's Avatar
i took off the ground on the battery for half hour....rechecked the codes....got a code for a throttle position sensor....i unplugged the throttle position sensor and started it up....runs great now just higher idle....so im assuming i have a bad TPS
ENVIUS is offline
post #6 of 8 (permalink) Old 07-07-2012, 12:28 PM
cadillac_rancher's Avatar
Do you have your IAT sensor hooked up to the silicone adaptor? Also try cleaning your maf with some electronics cleaner and see how that goes.
94 DCM FWB V4P w/ sunroof
Intake, Exhaust, 280 XFI, NSA 1.5rr w/ Bullet Vs2700 Springs, Built 643 heads/intake, L67 32.2lb Injectors, Mild Trans, Edge 3600, SS Springs, Belltech Drop Shocks
Wrecked.......
94 DGGM Z28 M6
1962 Imperial Crown 4 door hardtop
cadillac_rancher is offline
post #7 of 8 (permalink) Old 07-10-2012, 10:45 PM
CoupeDTS's Avatar
Sounds like TPS. Don't be tempted by the cheap ones on ebay! Go to the parts store and spend the few bucks extra believe me
Known for slammin' Cadillac Doors!
1996 - Fleetwood Brougham Black on Black V4P
1983 - Coupe Deville - Street Custom Show Lowrider
1970 - Calais 4dr HT
CoupeDTS is offline
post #8 of 8 (permalink) Old 07-11-2012, 06:02 PM Thread Starter
ENVIUS's Avatar
well guess what...the mechanic at the shop used the incorrect firing order ...the drivers side had 2 wires in the wrong position on the opti....i swapped them out to the correct position....cars sounds normal now...its about 95% perfect again..still has an odd idle but you can here the cylinders are all firing correctly now.....i guess next time ill just do it my self....i went with a shop with a good name only with intentions of not sweating my ass off in 100+ degree temps and so i could just get it fixed and drive it again......lesson learned i guess
ENVIUS is offline
