Racetronix wiring harness - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 10-16-2012, 11:41 PM Thread Starter
RE LAC SN's Avatar
I received my racetronix BLT1 fuel pump wiring harness today with a new bulkhead connector assembly. The fleetwood has 4 wires where the B bodys have 3(the fuel pump and sender share a ground). In looking at this, I am a little confused. I hook up the wire in the front to the alternator and run to the back of the car. Mount the supplied fp relay and ground near the tank (about 6 inches of wire from relay to the connector to attach bulkhead connector). Here is where I'm lost. From the relay I have 4 wires, 1= red to front(alternator) 2=black to ground, 3= gray to male connector, 4=red to female connector. Each of these 2 connectors have a black wire going to ground and then a purple wire connecting the two. The bulkhead connector is male and the colors match the female connector (I assume I will just add a ground wire to the yellow bulkhead that goes into the tank and run the 2.5 ft to the common ground by relay). My question is "where does the other connector go?"
77 Chevy Caprice Classic
80 Chevy Caprice
81 Buick LeSabre Coupe
84 Chevy El Camino Conquista
94 Buick Roadmaster Sedan
07 Cadillac CTS
RE LAC SN is offline
post #2 of 2 (permalink) Old 10-16-2012, 11:46 PM Thread Starter
RE LAC SN's Avatar
There is a similar thread in the engine problems maintenance section but with our cars being different I thought I may get more help here. Thanks
https://www.impalassforum.com/vBullet...d.php?t=256821
80 Chevy Caprice
07 Cadillac CTS
