Traction Control light - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 10-23-2012, 01:00 PM Thread Starter
RYS
RYS's Avatar
Send a message via AIM to RYS
I've got the traction control light on in my Fleetwood. I pulled the codes and got the following.
C0064 Throttle Position Signal Malfunction
C0073 Spark Retard Monitoring Malfunction
Is the TPS bad? What values should I be seeing with a scan tool? Can it be re-calibrated? Thanks guys.
1994 Chevrolet Caprice Classic LS - LT1 swap ect..
1996 Cadillac Fleetwood Brougham - Sprint springs
RYS is offline
post #2 of 4 (permalink) Old 10-28-2012, 04:45 PM
CoupeDTS's Avatar
i believe it works between 0-5 volts. My FSM tells how to test it, prob just probe a wire and see if it has a smooth ride from 0-5 volts. Otherwise they are only 20 some bucks and easy to change. Usually when they go bad youll have a really bad 1-2 shift.
Known for slammin' Cadillac Doors!
1996 - Fleetwood Brougham Black on Black V4P
1983 - Coupe Deville - Street Custom Show Lowrider
1970 - Calais 4dr HT
CoupeDTS is offline
post #3 of 4 (permalink) Old 10-29-2012, 07:40 AM Thread Starter
RYS
RYS's Avatar
The funny this is, the car runs/drives and shifts perfectly.
RYS is offline
post #4 of 4 (permalink) Old 10-29-2012, 08:40 PM
CoupeDTS's Avatar
could depend on HOW its broke. Maybe if it malfunctions in the lower range it will shift bad and if it malfunctions in the upper range it will throw a code. Who knows. If it throws a code though something is wrong
CoupeDTS is offline
