Theft Deterrant Module - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 06-08-2013, 09:16 PM Thread Starter
Hello all:
Can anyone tell me if the TDM is in the same place as in the Impalas? I've been reading that it is under the dash just above where the brake pedal is, above a black metal plate.
I need to bypass it, since the key bypass didn't fix the problem. I've already tuned the VATS out of the PCM, now I just need to jump the A4 to B5 pins.
I just want to make sure I'm looking in the right place on the Fleetwood.
Thanks.
Constantine
cadillac531 is offline
post #2 of 6 (permalink) Old 06-18-2013, 04:02 PM
RE LAC SN's Avatar
In the fleetwood it also goes by Remote Control Door Lock Receiver/Theft Deterrent Module. It's located under the rear high mount brake light cover. After pulling off the cover look through the back window to get a better idea of how to pull it out. I just pulled up on mine and it came out.
77 Chevy Caprice Classic
80 Chevy Caprice
81 Buick LeSabre Coupe
84 Chevy El Camino Conquista
94 Buick Roadmaster Sedan
07 Cadillac CTS
RE LAC SN is offline
post #3 of 6 (permalink) Old 07-01-2013, 09:45 PM Thread Starter
Thanks for the reply. I went ahead and bypassed it completely. You wouldnt know how the idiot light bulbs come out that are on either side of the speedo do you? I tried to remove the bulb for the pass key fault, but it just wouldnt come out...it broke instead. Thanks.
post #4 of 6 (permalink) Old 07-31-2013, 07:55 AM
RE LAC SN's Avatar
If I remember correctly you pull the cluster out and there are green light sockets that you twist and pull that houses the bulbs. You'll probably need some needle nose to squeeze the tabs to twist them.
80 Chevy Caprice
07 Cadillac CTS
post #5 of 6 (permalink) Old 07-31-2013, 07:57 AM
RE LAC SN's Avatar
Sorry a little late on that one. just seen you already got an answer.
80 Chevy Caprice
07 Cadillac CTS
post #6 of 6 (permalink) Old 08-01-2013, 12:54 AM Thread Starter
No problem. Thanks again.
