hesitation in reverse - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 08-04-2013, 06:57 PM Thread Starter
biggmay27's Avatar
my 95 hesitates when accelerating in reverse and will sometimes die when you let up off the gas. sometimes sputters in drive upon takeoff under mild acceleraton. any ideas?
biggmay27 is offline
post #2 of 2 (permalink) Old 08-05-2013, 01:34 AM
Mr pogo's Avatar
the usual suspects are fuel pressure, egr and opti if there are no codes.
Mr pogo is offline
