sensor in transmission line - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 10-04-2013, 09:32 PM Thread Starter
I just got done putting my new engine in and in the process of either removal or installation I accidentally smashed this sensor. It is in a 3x3 block off what looks to be the pressure side of the transmission line about 6 inches off the transmission on the passenger side.
My question... Do I need this or can I just run a new trans line without it. My fear is it is used by pcm to determine the trans temp and therefore the lockup of the converter due to temp... If I do need it, does anyone have a part number? The stealership can't seem to figure out what I'm talking about.
o btw its a 94 fleetwood Thanks!!!!
caddydriver501 is offline
post #2 of 10 (permalink) Old 10-04-2013, 09:40 PM
Try Hamilton Chevrolet.
post #3 of 10 (permalink) Old 10-04-2013, 09:43 PM Thread Starter
So I'm taking it I do need it? I can't go without... Where is Hamilton chevy? I'm near grand rapids in michigan.
post #4 of 10 (permalink) Old 10-04-2013, 09:44 PM Thread Starter
Is it the one in warren michigan?
post #5 of 10 (permalink) Old 10-04-2013, 10:55 PM
I've heard people claim it's not needed. The factory trans line w/o sensor block is much cheaper. There are a bunch of posts/threads discussing this.
post #6 of 10 (permalink) Old 10-04-2013, 11:02 PM
streetcar2try's Avatar
Not really needed and won't even throw a code. My suggestion is to AN the lines.
94 ImpSS, Currently a 24x 383 LTx. Built by Me.
Machining by Competition Automotive & Machine
Harness by BP Automotive (Bill)
Tuning by James at Shortuning.com
Mike Harris Crossmember
much, much more....
streetcar2try is offline
post #7 of 10 (permalink) Old 10-05-2013, 08:36 AM
94MSP9C1's Avatar
Here you go:
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
This should solve your problem but send me your VIN through the auction so I can verify it for you.
Mike--Hamilton Chevy
94MSP9C1 is online now
post #8 of 10 (permalink) Old 10-05-2013, 08:53 AM Thread Starter
ok I deleted it last night, and the converter won't lock up, is this in the tune to recognize the temp before it locks up?
post #9 of 10 (permalink) Old 10-05-2013, 12:28 PM
Mr pogo's Avatar
the tc wont lock up until the trans reaches a certain temp but the temp sensor that is involved is part of the valve body pressure switch assembly.
the outside sensor is only for trans overheating situation.
Mr pogo is offline
post #10 of 10 (permalink) Old 10-05-2013, 12:37 PM Thread Starter
Ok. I'm pretty sure after doing a ton of research the guy who did my tune put the wrong bin file in seeing it's a 94 it's unique with the way it sees the tcc for lockup. Is there anyone in Michigan near grand Rapids that has the ability to tune that actually knows what they are doing? The original tune I had on it was from vince at trifecta motorsports but he no longer supports the lt1 obd1 anymore. He did a fantastic job and the shop that tuned it imo ripped me off. Thanks
