2 piece throttle cable??? - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 12-24-2013, 03:34 AM Thread Starter
BeaSStin's Avatar
I have a 93 fwb and the throttle cable broke.
All the replacement cables are one piece.....
The cable that is on my ride is a two piece cable.
Where in the hell can i find the detent cable i need?
Can i rig a single piece cable to work?
'95 9c1 Caprice SS: paid $1200 143K UNDERGOING ENGINE REBUILD! Aerochambers, X-pipe, afterburners, bonnies, ss grille, monroe ss, 3 inch ex tips, indy 500 tires, TB bypass, Airfoil, Performance Trans built by MYSELF!
BeaSStin is offline
post #2 of 13 (permalink) Old 12-24-2013, 05:47 AM
isn't one of them for your cruise control?
when you don't know what to do,do what you know
ahoora is offline
post #3 of 13 (permalink) Old 12-24-2013, 02:20 PM Thread Starter
BeaSStin's Avatar
They all go in to this pulley system thats under a plastic cover
BeaSStin is offline
post #4 of 13 (permalink) Old 12-25-2013, 12:02 PM
V8killer's Avatar
it's traction control (ghetto TC). if you ever break the tires loose you will feel the gas pedal kick up right under your foot.
B-bodies didn't get that option. only fleetwood as far as i know.
STOLEN ON JUNE 8TH OR 9TH 2003 FROM TACOMA,WA
ISSF MEMBER #282
94 9C1,SS clone,DCM,SSRI,HA/F-body sway bars,3.42's Bonnies,floorshift,Stillen front,Smoothy rears,billet grille,white face Z-28 dash, Dynomax mufflers,Tri-Y,eibach,J&M control arms,NOS 100 shot,MSD digital+6&coil,MSD super conductors,metco safety loop,Dynotech driveshaft [email protected]
V8killer is offline
post #5 of 13 (permalink) Old 12-25-2013, 03:29 PM Thread Starter
BeaSStin's Avatar
Ok so how do i get my trans to work if the two piece cable is no longer available?
Can i run a tv cable from the the throttle directly to the trans?
BeaSStin is offline
post #6 of 13 (permalink) Old 12-26-2013, 09:44 AM Thread Starter
BeaSStin's Avatar
Help anybody?
BeaSStin is offline
post #7 of 13 (permalink) Old 12-27-2013, 03:46 PM Thread Starter
BeaSStin's Avatar
Nobody has any other input at all?
BeaSStin is offline
post #8 of 13 (permalink) Old 12-27-2013, 05:26 PM
If the sheath is still good, and you have the cable (complete end to end), you could probably have a new cable portion made. Find a place that makes cables (custom motorcycle shop) and take the entire cable and sheath to them. They can make a new cable (you need the ends for comparison, and length for correct fit) with your sheath. They may have to cut a longer premade cable to use in your sheath if they do not have bulk cable. The ends are pretty much standard, but there are a few different types. The ends are swaged onto the cable, so there aren't any weird tool needed.
There may even be someone on the internet who makes custom cables.
Your other option is to get one from a junk yard.
post #9 of 13 (permalink) Old 12-28-2013, 04:26 PM Thread Starter
BeaSStin's Avatar
The end of my cable is broken. I cant find one in the junkyard so far.
Im thinkin that i can rig one directly to the throttle
BeaSStin is offline
post #10 of 13 (permalink) Old 12-28-2013, 08:40 PM
If you can determine what shape the end was, the cable can be remade with a new cable in the old sheath. It is a swaged piece that makes a T at the end of the cable. That end of the throttle cable is the same as the cruise control cable that is attached next to it. If the end is the one to the throttle pedal, it is a tubular piece swaged to the cable end. It is the same as all B body cable ends for the pedal side of the cable. You can remove the CC cable to take with you if that is the end that is missing. Take the original throttle cable and sheath so one of the same length can be made for use in your sheath. It should cost you about $20.
There are no other cables for the B or D bodies that are adaptable to the Fleetwood.
