Flip Down Install - Chevy Impala SS Forum
post #1 of 31 (permalink) Old 12-06-2010, 09:41 PM Thread Starter
redbubble24s's Avatar
Send a message via AIM to redbubble24s
Flip Down Install
Anyone ever installed their own flip down? I'm not too worried about the wiring aspects of this, just looking into the mounting aspect of it.
redbubble24s is offline
post #2 of 31 (permalink) Old 12-07-2010, 11:48 AM
Its real easy. Plus the power and ground you need are right there from the dome light. When I installed mine I fabbed up a bracket that I mounted to the dome light bracket. Once you get the headliner down you will see what I am talking about. Been installed for around 7 years with no issues at all.
95 DCM Imp SS....Daily Driver 98k and counting
72 Cutty............Weekend cruiser.
Nor-CalSS is offline
post #3 of 31 (permalink) Old 12-07-2010, 04:16 PM Thread Starter
How big is your tv? I figured there may be a little bit more involved for a larger tv?
post #4 of 31 (permalink) Old 12-16-2010, 07:58 AM
when i do larger screen installs i take the headliner down and screw a piece of 1/4 mdf to the bracing that goes across the "ceiling" then put headliner back up screw metal plate into the board and screw screen into plate
ramos7 is offline
post #5 of 31 (permalink) Old 12-20-2010, 09:23 AM
305classic's Avatar
I wired mine to my domelight and it ended up killing my battery even when the was off so make sure you wire in a switch to the main power wire going into your TV
305classic is offline
post #6 of 31 (permalink) Old 12-13-2011, 06:50 PM
rileycoastie's Avatar
any updates on this type of install. i will be putting in one this winter?
WHO DAT NATION! ISSCA#2463
95 DCM/BBB SS-22" U2 55, 3D Polished Grill, Custom Audio, Double din DVD "flip out", Hooker Headers, 2.5 Flowmaster 40 Series, Underdrive pulley, F Body MAF, Tuned, Shift kit, 160 thermo, Euro Headlights, DDM Tuning HID's 55W 6000K, Smoked Tails with LED sequentials , Custom black carpet, Corvette starter, Yellow top optima, Big 3 upgrade, Smaller alternator pulley.
rileycoastie is offline
post #7 of 31 (permalink) Old 12-23-2011, 12:38 AM
I just installed mine today. used the power from dome light. for some reason the interior lights wont go off. i have to pull the fuse to get them to turn off. any suggestions????
post #8 of 31 (permalink) Old 12-23-2011, 02:34 AM
Door Jamb Switch??
1994 Caprice 5.7 with 55,xxx miles, still going.
jd87sep is offline
post #9 of 31 (permalink) Old 12-23-2011, 07:11 AM
Don't think that's the issue. It still does it with doors open or closed... Maybe the whole interior lighting system is a circuit and when I took down the dome light I jacked it up...
post #10 of 31 (permalink) Old 12-30-2011, 05:58 PM
Don.V's Avatar
That looks goooood! Can u post more pics but in different
angles, I really like dat.
Don.V is offline
