Double din harness - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 01-05-2013, 10:48 AM Thread Starter
NEWkie-969c1's Avatar
Double din harness
Hello everyone I have a pioneer avh 3100dvd player and I was wondering if I needed a special harness to hook it up to my 96 caprice, I already have a few of the harness that go to regular single din cd players.
Erick
Sent from my PC36100 using AutoGuide App
96 caprice K&N FIPK X pipe flowmaster 40 series lowered lt4 starter 6 way bonnies true trac 373s rebuilt heads/kenwood BT742U MGA 4150 amp 6.5 kicker DS 6.9 infinity kappa 2 12 MEMPHIS PR 2 farad cap
NEWkie-969c1 is offline
post #2 of 11 (permalink) Old 01-05-2013, 12:36 PM
94MI9C1's Avatar
You shouldn't need anything particular, a standard Metra style harness should work. I am assuming that you do know that you will have to rework the center dash, like I did on my double din install, to make it work. Also DetailSS makes a kit for it, in case you didn't know. Good Luck.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #3 of 11 (permalink) Old 01-05-2013, 01:13 PM Thread Starter
Thanks for the quick reply and yea I know that I need to work the dash and I will be ordering the detailss kit soon I was just making sure I didn't need anything special before I was gonna order the kit that comes with the antenna adapter and harness but I already have those so thank you for saving me some money and a head ache .
Sent from my PC36100 using AutoGuide /l
post #4 of 11 (permalink) Old 01-05-2013, 10:32 PM
94MI9C1's Avatar
No worries, you should be good with the standard install kit. That is what I used
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #5 of 11 (permalink) Old 01-05-2013, 11:36 PM Thread Starter
Again thanks for your time but quick question my double din only has two preamp out puts one for front speakers and one for subwoofer my current Kenwood has three preamp outputs and thats how I have my subs and 4 speakers are connected my question is how or what do I have buy to install my audio correctly
post #6 of 11 (permalink) Old 01-06-2013, 08:32 AM
94MI9C1's Avatar
That is weird. I would assume that you are interfacing to an amp that you have. Does the amp have high level inputs into it? IF so you would have to run it this way, if not you would have to do a converter, something like this http://www.amazon.com/Audio-Systems-Level-Converter-B65N/dp/B000LP4RMQ
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #7 of 11 (permalink) Old 01-06-2013, 11:37 AM Thread Starter
Yes I do have a amp, and that's how my current setup is hooked up.I'm kinda confused on what that converter is and I'm sorry if my question is hard to understand I'm not so good with audio and explaining things.
Well just to reiterate I have 3 sets of rca cables that go to there specific location on my Kenwood one is front speaker one is rear speaker and one is subwoofer.the speaker rcas go to my 4 Chanel amp and and the sub go to my mono amp I use both amp to control the high and low filters for all my speakers. My current receiver is the pioneer avh3100 dvd this unit only has a front speaker and sub output were or how do I wire my rear rca so I can have all my speakers connected.
Sorry for asking a dumb question and thank-you for taking time to read it and try to answer it.I have been googling and asking all my so called audio guru friends and they all give me the same blank stare and vague answer.
If it helps my 4 Chan amp is a bazooka mga150.4 my rear speakers are 6x9 infinity kappa fronts are kicker ds6.5 components
post #8 of 11 (permalink) Old 01-06-2013, 12:47 PM
94MI9C1's Avatar
Ok I know what you are talking about now. On the AVH that you have the rear channel RCA's are dual purpose for either Sub or rear. Now to do it correctly, you should get a http://www.onlinecarstereo.com/CarAu...DEQ-P8000.aspx
But I guess that you can use a RCA "Y" adapter at the amp and use the front channel to drive both front and rear channels
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #9 of 11 (permalink) Old 01-06-2013, 12:52 PM
94MI9C1's Avatar
Not sure if you have the manual for the AVH or not, but here it is http://www.pioneerelectronics.com/St...Manual1126.pdf
That is the only way that I know that you can do it, now the EQ is discontinued and you would have to get one from Ebay or where ever, if you do this make sure that it comes with the optical sensor to control it.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #10 of 11 (permalink) Old 01-06-2013, 04:38 PM Thread Starter
