Stainless ABS delete lines - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 02-24-2016, 03:31 PM Thread Starter
SSandman's Avatar
Hey all,
I know there has been some demand for a complete set of stainless steel ABS delete brake lines. I finally found someone willing to make them, but I have one issue. Don of Classic Tube said he could do it and would be able to provide special pricing for a group purchase type deal, but he would need a template to bend them from. I have no problem with doing this, but it may be a little while till my car is together enough to do this.
Is anyone interested in this, and would anyone be willing to help by creating a template? See the email attatched below!
SSandman is offline
post #2 of 13 (permalink) Old 02-24-2016, 04:42 PM
Hell yeah!! I'd be down for a set but don't have anything I could provide Ina template though. Another company to contact would be inline tube if this does not happen with Classic tube. There was also some talk that the pre 91 boxy Caprice (85-90?) may work or at least route the same. I believe the fittings and flare type could be different though.
I seem to remember a recent thread where someone was also looking at doing Abs delete but can't seem to find it. T may have been Bill (NavyLifer) or maybe that was body bushings he was looking at getting done. Theses things start to blend together after a while.
This may be the thread I was thinking of....but based on the Author of it, you probably were already aware. :>)
https://www.impalassforum.com/vBullet...ess+brake+line
post #3 of 13 (permalink) Old 02-24-2016, 05:01 PM
Im in for set also, i just bought a wrecked 96 Roadmaster wagon that i will completely parting out if that will help for a sample set.
KDB50SS is offline
post #4 of 13 (permalink) Old 02-24-2016, 05:38 PM
96SSbbb's Avatar
I wouldn't mind picking up a set.
ISSCA# 930
96SSbbb is offline
post #5 of 13 (permalink) Old 02-25-2016, 11:38 AM
I am in for a set
dans95 is offline
post #6 of 13 (permalink) Old 02-25-2016, 09:24 PM
Small vendor
BigBlackBeaSSt's Avatar
I am in for my wagon. I am removing a set of stock lines from my Impala to install a full set of SS lines (with ABS). If I can be of help to get a prototype now IS the perfect time.
BigBlackBeaSSt - 94' BBB lots of mods.*** 94 DGGM Woody Wagon to many mods to list
PM ME FOR BLEEDER VALVES.
BigBlackBeaSSt is offline
post #7 of 13 (permalink) Old 02-26-2016, 02:51 PM
dirtyharry's Avatar
Just deleted my abs. But I'm down for some stainless steel lines
D.C INC........ Trigger Man
Got work? Got mods? Got LSX?
dirtyharry is offline
post #8 of 13 (permalink) Old 02-26-2016, 03:28 PM Thread Starter
SSandman's Avatar
Nice!
KDB50SS, so you have a complete set of factory brake lines? Are the RMS lines the same as the Caprice/Impala? If so, I'd be willing to buy them from you and start working to mock something up on my own car and tweak it according to what everyone wants as far as routing.
It may be better if someone with more time and a car that is fully assembled does the work though, but if we can't find anyone then I'll gladly do it.
BigBlackBeaSSt, you definitely may be able to help! If you have a complete set of lines, all you'd have to do is figure out a clean way of merging the lines to delete the ABS (do it however you like, obviously it doesn't need to be functional, just needs to have the shape/routing right) and then we can send it in to Classic Tube. i'll cover the shipping costs. If anyone is up for chipping in a few bucks to whoever does the mock up work maybe we a knock a few dollars off of their kit for the effort.
SSandman is offline
post #9 of 13 (permalink) Old 02-27-2016, 08:20 PM
Small vendor
Originally Posted by SSandman View Post
Nice!
I have a BN set of SS lines from classic ready to go on. I can compare and bend up some copper tubing to impersonate the lines. I will see what I can do.
post #10 of 13 (permalink) Old 02-28-2016, 11:33 AM
juniorwatson's Avatar
I'd be interested in a set.
Thanx.
juniorwatson is offline
