Any Interest in Classic Tube Products? - Chevy Impala SS Forum
post #1 of 12 (permalink) Old 09-06-2010, 10:25 PM Thread Starter
I'm going to be calling the folks at Classic Tube in Lancaster, NY tomorrow because I need to get some pre-bent transmission lines for a Chevy Truck. There was a group purchase for stainless steel brake lines from Classic Tube several years ago. I was pleased with the sets that I got for my 96 Caprice with rear drum and my 96 DCM.
I'll ask if they would offer any discounts for a group purchase. They offer pre-bent stainless steel sets for the brakes, transmission, and fuel lines.
rwd4evr is offline
post #2 of 12 (permalink) Old 09-07-2010, 12:59 AM
If you can swing a GP on the trans lines put me down for a set. Mine need to be replaceds, starting to rust through, but if not for that the lower transmission to radiator connection is rusted into the radiator connector. I can probably get the radiator fitting out but I will have to trash the current lines on the car. Also what would be the correct part for a '95 9C1 the 4 piece kit or the 5 piece kit? GM lists the same cooler lines for all 94 to 96 vehicles. However the Classic Tube site lists a 4 piece kit for the 91-95's and a 5 piece kit for the 96's . If you can find that out that would be appreciated. And if they can do a GP on them even better, but at minimum finding out the correct set of lines to order would be great. - Peter
Peter Cordes
1995 Caprice SS/9C1 Black w/ tan leather interior
1993 Ford Escort LX Mocha Frost Metallic w/ tan interior
pcordes1979 is offline
post #3 of 12 (permalink) Old 09-07-2010, 07:50 AM
GA95DCMSS's Avatar
Send a message via Yahoo to GA95DCMSS
Check with Inline tube also. IIRC, their kits are cheaper, and stainless steel is the same price as mild steel lines.
Quentin-1995 Impala SS-. New PB coming soon
GA95DCMSS is offline
post #4 of 12 (permalink) Old 09-07-2010, 09:47 AM Thread Starter
Inline Tube vs Classic Tube Info
Inline Tube is in Michigan. They have hard line brake sets listed for the 1991-96 Caprice and Impala SS (depending on if you have rear disc or drum brakes). The standard cost from Inline Tube is $185 for a set of stainless steel brake lines. They do not have any tranny lines or fuel lines listed on their website for our cars. I will call to ask if they have any patterns scanned into their system for the other lines. I'm specifically interested in fuel lines and tranny lines since I already have stainless steel brake lines for both my Caprice and Impala SS.
Classic Tube is near Buffalo, NY. They have stainless steel hard lines brake sets for the 1991 - 96 Capice and Impala SS listed at $225. The 5 piece tranny line set in Stainless for the 96 Impala ss and Caprice with the external tranny cooler is $99. The fuel line in Stainless for the 96 Caprice/Impala SS is also $99.
So, based on the cost of the brake line sets, if Inline Tube can make fuel lines and tranny lines for the 91 to 96 B-bodies, then they will probably get my business because they already have all of the lines that I need for my 94 Chevy K1500. I'll let you know what I find out.
rwd4evr is offline
post #5 of 12 (permalink) Old 09-07-2010, 10:52 AM
Oh and I forgot to mention this there are different lines used for the L99 w/ external trans cooler and the LT1 w/ external trans cooler. The lower(on the transmission port and radiator port) line on the LT1 line has a TCC temperature sender & block whereas the L99 one does not. And of course the L99 w/ only the radiator transmission cooler uses a different upper line which does not allow for the external cooler.
Looking at Inline Tubes catalog they only have the brake lines for the 91-96's, albeit at a better price than Classic Tube, Inline Tube part # CFB9102 for 94-96 w/ rear disk and CFB9101 for 91-96 with rear drum, not the transmission cooler lines. - Peter
Peter Cordes
post #6 of 12 (permalink) Old 09-07-2010, 11:17 AM
Mean SS's Avatar
Send a message via AIM to Mean SS
I got my brake lines from Inline, they don't come with the 2 short ones from the master and 2 of the lines they sent were bent wrong
Mean SS is offline
post #7 of 12 (permalink) Old 09-07-2010, 12:01 PM
JZ9C1LT1's Avatar
I was in GP brake line kit a few yrs ago from Classic Tubes for my 96 Caprice. I only used the ABS lines to the master cyl and they fit almost perfect, just needed a little bending.
96 9C1 LT1 with all the bolt on crap (Gone 1/08 to 9C1 heaven aka junkyard!)
95 9C1 LT1 New toy as of 6/09 (this one is now heading same direction as the 96)
95 9C1 LT1 The new black mariah! SOLD
95 9C1 LT1 Will be my whenever I get it done project!
94 Caprice
04 GTO SOLD
Originally Posted by BewbZowt(+ Y +)
Here's how it works: If I can see them, they are real.
JZ9C1LT1 is offline
post #8 of 12 (permalink) Old 09-07-2010, 02:08 PM Thread Starter
I just talked to a guy in "tech support" at Inline Tube. They do not have ANY patterns for the transmission lines or fuel lines for a 1991 to 96 Caprice or Impala SS. The catch-22 is that they would be happy to scan someone's lines if you have a set sitting around. I started down this path because I need all sorts of hard lines for my truck. the difference in the cost of the brake line set from Inline Tube to Classic Tube is a whopping $109!! It makes me wonder what's missing if one set is so much cheaper!
More to come once I talk to a sales person instead of the technical support guys.
rwd4evr is offline
post #9 of 12 (permalink) Old 09-07-2010, 03:03 PM
juniorwatson's Avatar
I would be interested in a set of transmission lines if a GP is in the works.
When I did a frame off resto on my 1970 Olds 4-4-2, I used 'The Right Stuff' for stainless brake and fuel lines. Everything fit perfectly, fast shipment, and excellent customer service.
They are locted here: http://www.getdiscbrakes.com/RightStuff/Default.aspx
As consideration for another supplier if we can't get Inline to reproduce them.
juniorwatson is offline
post #10 of 12 (permalink) Old 09-07-2010, 03:35 PM
Right Stuff
Funny, when I needed brake lines for my 88 Chevy truck Right Stuff jerked me around considerably before I got what I wanted. I'll never buy anything from them again if I can help it. I sent them all the line from my truck so they could scan them and put them in their catalog. They couldn't find them, they would be done 'next week' and they got the lines from the master to the prop valve wrong.
Your results may vary.
Ken Hennessy
Ken Hennessy is offline
