double din GP with thedetailss.com - Chevy Impala SS Forum
post #1 of 48 (permalink) Old 09-12-2010, 08:03 PM Thread Starter
Anyone in?
96 DCM - 355 LE2 - SS3600 - Bolt Ons - Hotchkis - 3.73 - Trifecta Tune
sdotlog is offline
post #2 of 48 (permalink) Old 09-12-2010, 08:28 PM
etc.'s Avatar
I might be in.
However, the GP price will have to reflect the fact its a fancy piece of plastic...
1996 Caprice 9c1
etc. is offline
post #3 of 48 (permalink) Old 09-12-2010, 08:38 PM Thread Starter
So its outright 150 shipped bit 5 or more saves 10 dollars. Comes smooth or textured.
sdotlog is offline
post #4 of 48 (permalink) Old 09-12-2010, 09:15 PM
chydog's SS's Avatar
yes
I'm in if it goes - lmk mike
96BBB 63K PCM4Less, 3.73 K&N FIPK, Delete\'s,stealth bolt Bilsteins Alpine HU RF 6 channel/Image Dynamics,Kaotic upper/lower CA,. Racetronix FP, garys headlight harness,
2010 GMC Crewbab - Storm Grey stock, Line-X
LT1 stroker - Forged Compstar 383 supplied by Ellwein, AI 200 cc competition heads, GMPP 846 cam, CIA tri-y's, OBD I conversion tuned by alex
http://www.cardomain.com/ride/241521...evrolet-impala
chydog's SS is offline
post #5 of 48 (permalink) Old 09-13-2010, 04:21 PM
Send a message via AIM to 32assasin
Originally Posted by etc. View Post
I might be in.
its more than just a fancy plastic
if you make your own costume install you will most likely spend more time creating the mounting bracket. I know I did
https://www.impalassforum.com/vBullet...ighlight=lower
I bought a universal install kit with a eq mount and I spent hours modifying it to mount in my car, and after I mounted it I spent more time reinforing it to hold the weight of a single din and eq. a double din unit is much heaver then my single din and eq combined, you just cant cut a piece of abs plastic and expect it to hold.
is the mounting bracket and fancy piece of plastic worth $150? probably not but you should ask this guy how much he payed for his custom install
https://www.impalassforum.com/vBullet...d.php?t=247360
from their you can go gauge on how much money you will spend and how much money you will save with this kit.
95 BBB 1 of 18,649 made
32assasin is offline
post #6 of 48 (permalink) Old 09-15-2010, 08:22 PM
Slimer's Avatar
I just bought 1 last week. Kit looks great. Can't wait to get it installed.
Slimer is offline
post #7 of 48 (permalink) Old 09-16-2010, 02:14 PM
I would be interested. Anyone have pics?
Matt MF'N Mills 96 Black SS NAISSO Member #6125
Mods: T-56, Suncoast Ram Air Hood, S-Class Mirror LEDs (thats right bitches), Smoothie Bumpers, 50% windshield tint, Train Horns, Clear Corner Lenses, Corvette Engine Dress, 2.5" Custom Exhaust, Carbon Fiber dash, Oil, Volt, and Vac gauges, 3 Gauge Pod, Body Bushing upgrade, T/B bypass, Red Bowtie, LT4 Knock Sensor, F-Body EGR valve & Servo, Moog suspension, A/C drip mod, SEM Blacked out interior, CIA Headers
www.lightingprogrammer.com
Matt M is offline
post #8 of 48 (permalink) Old 09-21-2010, 02:45 PM
Pictures at www.thedetailss.com . . .
I bought it a few weeks ago too. It does save a lot of customization time. The bracket part works perfectly & is simple. I had zero issues getting it installed & ready to go for my stereo installer.
The part that's tougher is cutting out the center section of the dash that will fit well to glue in the replacement face plate. I wish I took some more time on it than I did. FYI: this isn't a kit issue as much as it is the time you take to do it right issue. I was rushed and did do enough testing/fitting/cutting to ensure a nice flush fit.
Also, I think I would prefer the smooth one because the textured one is way more textured than stock & smooth would actually be closer to stock than the textured. When I ordered it, I wanted the textured to match the dash, but they are worlds apart.
Here you can see some of the epoxy (lower left) & exposed cuts (across top):
Here you can see the extra space on the bottom, but the face needs to swing down some to open/close:
Prior to cutting the center section & disconnecting the AC controls:
Backside of the AC controls for reference to reconnect, in case I forgot:
'96 DGGM - Phoenix Transmission w/2000 stall - Frankenstein Cat-Back (love it!) - PPM Extra Duty Front End Kit
- 4 curb rashed rims, 3 dangling windows, 2 grenaded transmissions, 1 holy seat, and a wreck in May 2006
'06 Cadillac CTS-V (stock . . . for now)
BEAT YOUR SPEEDING TICKET: www.tipmra.com
LAYGO is offline
post #9 of 48 (permalink) Old 09-22-2010, 01:45 PM Thread Starter
Damn. Don't know if I want it anymore. Doesn't
Look as good as I thought it would
sdotlog is offline
post #10 of 48 (permalink) Old 09-23-2010, 11:28 AM
Don't let my poor install dissuade you. The kit is immensely helpful. I don't regret the price because it would likely cost AT LEAST twice that to pay someone to fabricate it. Then you would *STILL* be left to fabricate the face plate! The fitment of the bracket was absolutely perfect. I did not take enough time to fit the face plate & regret that.
If I can find a replacement lower dash in good condition, I will try again & take my time. I was rushed because I was trying to get it done right before having it installed. I took the least amount of time on the most visible part! DUMB! It's one of those live & learn moments, but you only get one shot.
I would recommend the smooth face vs the textured one (pictured above) though.
LAYGO is offline
