Sway Bar GP redux - Chevy Impala SS Forum
post #1 of 42 (permalink) Old 03-15-2011, 01:21 PM Thread Starter
Navy Lifer's Avatar
Sway Bar GP redux
Some of you participated in the wagon bar GP that ran for a period of time in late 2009 with a few stragglers into 2010.
I've had several inquiries recently about the availability of sway bars from this source.
In order to run another GP, a minimum of 5 bars must be produced in any of the configurations that were offered--read through the link above (from the original GP) for specific bar choices, and if interested PLEASE contact me via PM or e-mail, even if you also post here.
This is an open-ended solicitation that I'll let run for 45 days (to the end of April, basically) or until enough interest is shown to take orders and get a run of bars made.
Pricing is not set or guaranteed - not tied in any way to the previous GP, so do not think that the pricing will be the same (though it may be in the end).
Bill Harper
ISSCA #127
[email protected]
Navy Lifer is offline
post #2 of 42 (permalink) Old 03-15-2011, 03:32 PM
Cmdr. Flash Gumby's Avatar
I'll do it, Bill.
Assuming that the prices aren't too far out-of-whack with the old GP.
-Scott McGrath
'96 Roadmaster Estate Ltd. - Last of the Great American Wagons
Low 14's - But I've "Done some stuff to it."
http://www.cardomain.com/ride/2762557
ISSCA#2229 BCA#43406 BMD#115
Cmdr. Flash Gumby is offline
post #3 of 42 (permalink) Old 03-15-2011, 03:41 PM Thread Starter
Navy Lifer's Avatar
Scott, thanks, and if you don't mind, please PM or e-mail me too indicating your interest, including some idea of what you may be interested in--rear only or front & rear.
I will ask for an estimated current price, but I really do not think it will be significantly changed from the previous GP. That info will be posted in an update once I get it.
For now, assume "same price", but this thread is mainly to establish viability to run the GP.
Bill Harper
ISSCA #127
[email protected]
post #4 of 42 (permalink) Old 03-15-2011, 05:24 PM
The Stickman's Avatar
Bill how many bars were made the last time? If I remember right they are a total custom bend and are not in Hellwig's catalog right?
Neil P.
1996 Federal hearse. CAI, Delphi 3.5 MAF, Aluminum elbow, airfoil, coolant bypass mod, 36lbs injectors, LE 223/231 110 LSA cam, Trickflow pushrods, Comp Cams rocker studs, Lunati 1.6 roller rockers,double spring kit and lifters, F-body heads, Cometic MLS .027 head gasket, Hooker headers, Cloyes timing chain, PowerBond balancer, EGR, air pump and AC delete. Solomon tune. CPT Pro-Race trans, 9.5 inch 3200 stall converter, 9.5 inch 14 bolt rear, 4.10 gear and TruTrac helix gear diff
The Stickman is offline
post #5 of 42 (permalink) Old 03-15-2011, 07:09 PM Thread Starter
Navy Lifer's Avatar
Neil,
The bars are custom-spec "private label", not in the regular Hellwig inventory/catalog, correct.
I don't remember what the exact quantities were previously--some the supplier had on hand, and then we had enough demand to have them get more, but I do recall that the added run had to be a minimum of 5 of a specific type, as it is now.
My concern now is whether the Super Bar will even be available, as I recall saying/writing or being told that those would not be run again, but I can't find the statement to that effect.
Bill Harper
ISSCA #127
[email protected]
post #6 of 42 (permalink) Old 03-15-2011, 07:32 PM
oldsmike's Avatar
I'm in!
Oh and greetings everyone! Just joined...
Michael Hall - SE Michigan
The Stable
- 1972 442 W30, Viking Blue
- 1972 Cutlass S, Radiant Green
- 1987 Custom Cruiser, "Draggin' Wagon"
- 1996 C3500 Silverado, Turbo Diesel
- 1996 Cutlass Ciera, daily driver
- 2003 Alero, SO's daily driver
oldsmike is offline
post #7 of 42 (permalink) Old 03-15-2011, 07:37 PM
BigAdron's Avatar
Only for wagons again?
96 Pimpala SS, BBB Flaked Out, K&N CAI, CAT Delete, 40 Series Flowmasters
BigAdron is offline
post #8 of 42 (permalink) Old 03-15-2011, 07:51 PM Thread Starter
Navy Lifer's Avatar
Not necessarily--but the requests so far had been from wagon owners.
Sedans would be under the same "rules" - minimum of 5 bars of a specific size/application.
Front bars fit both sedan & wagon, so no issues with them.
What were you interested in? I would have to do the research to be sure what was available--should be several choices.
Bill Harper
ISSCA #127
[email protected]
post #9 of 42 (permalink) Old 03-15-2011, 09:24 PM
Nick Danger's Avatar
Unsolicited testamonial:
I was extremely happy with the 1-5/16" rear sway bar. I added the rear sway bar, fully boxed lower control arms, and an SS front sway bar at the same time, so I don't know how much each component improved the ride. But end result was great!
1994 Roadmaster Wagon.
Mrs Danger's site: www.unseengallery.com
Nick Danger is offline
post #10 of 42 (permalink) Old 03-15-2011, 09:44 PM
I have to say I love mine. Its a real shocker to most people to see a 1.5 inch rear bar. I have also jacked up one side of the car and had the other side raise up trying to keep the car level. I am doing an event in less than 3 weeks so I hope to use it all out on the track.
Neil P.
