Gear/Diff Group Purchase - Chevy Impala SS Forum
post #1 of 44 (permalink) Old 06-20-2011, 05:16 PM Thread Starter
Vendor
The GP price is in bold. I need a minimum of $4500.00 in orders to offer these prices. No exceptions as those are the terms from my supplier.
Call your orders in and we will get you set up. We will not bill anyone until the minimum has been reached.
New "Budget Posi" is listed at the bottom.
Thanks all.
Item Description Price
G001 3.42 Gears Yukon* $250.77 - 195.00
G002 3.73 Gears Yukon* $250.77 - 195.00
G003 4.10 Gears Yukon* $295.00 - 240.00
G004 ABS Reluctor / 342 - discontinued and not available anywhere.
G004.5 ABS Reluctor / 373 Only NOW IN STOCK!!! $35.82 - 31.00
G005 Pinion Install Kit for Gears $60.00 - 54.00
G006 Large Journal Carrier Bearings & Adjustable Shims for Torsen & Eaton (minimum requirements for installation of a posi) $70.00 - 50.00
G007 Large Journal Carrier Bearings $45.00 -35.00
G008 Adjustable Shims $35.00 - 25.00
G009 Axle Bearings & Seals $45.00 - 31.00
6001 Differential Additive (2 Bottles) $20.00 - 14.00
D6003 Eaton Posi (SuperBrute w/ 400# Springs) for Street & Strip Applications $487.95 - 439.00
D6004 Master Overhaul Kit for Gears and Differential (Includes Pinion Kit, Large Journal Carrier Bearings & Adjustable Shims) $153.20 - 131.94
D6005 Tru-Trak Posi (worm gears) for Street & Autocross/Road Course Applications $454.94 - 429.94.00
D6006 Yukon Duragrip 8.5 30 spline Positraction $466.40 - 411.85.
New ZVT "Budget Posi" $324.14 - 265.50
Clear Image Automotive (425)251-0329
Headers, exhaust & intake systems
[email protected]
http://www.clearimageautomotive.com/
Clear Image Auto (Dan) is offline
post #2 of 44 (permalink) Old 06-20-2011, 07:37 PM
3.73
You can put down for a set of 3.73's and a ABS reluctor.
y-burna is offline
post #3 of 44 (permalink) Old 06-20-2011, 09:36 PM
FuzzyNutzGoneWild's Avatar
I would like to do the 3.73 gears (G002) and Eaton posi (D6003). What other parts do I need to buy for the new set-up? (G004.5) ABS Reluctor for 3.73, (G005) Pinion Install Kit, (G006) Large Journal Carrier Bearings & Adjustable Shim.. Correct me if I'm wrong and what other parts I need/ don't need.
FuzzyNutzGoneWild is offline
post #4 of 44 (permalink) Old 06-20-2011, 10:54 PM
Steve-O_Knieve-O's Avatar
Is the Budget Posi a direct replacement or will I need other parts? Also is it available in the 3.42, 3.73 & 4.10 gearing or 1 specific ratio?
Steve-O_Knieve-O is offline
post #5 of 44 (permalink) Old 06-20-2011, 11:33 PM
by chance do you carry 3.23 gears and reluctor?
BiG 96 DcM SS is offline
post #6 of 44 (permalink) Old 06-21-2011, 12:52 AM Thread Starter
Vendor
For a gear only swap, a pinion kit is the minimum requirement.
A posi only sway requires large journal carrier bearings and adjustable shims.
To do both a posi and gears you will order a Master Overhaul kit which is a pinion kit with the carrier bearings and shims.
The "Budget Posi" will require the the same as any posi as described above. It can be ordered with any of the available gears.
I will check with my supplier for the 2.23 gears and reluctor ring.
Thanks.
[email protected]
post #7 of 44 (permalink) Old 06-21-2011, 01:35 AM
Thanks.
Thanks for the quick response. Now comes the decision to get the Budget gears or spend the extra $$ for the Eaton or Tru-Trak. Hmm...
Highly thinking about getting the 3.42s. 98% city driving along with this one wheel wonder & 3.08s are killing me. I understand I'll have to get the ABS reluctor custom but I believe it'll be worth it...
post #8 of 44 (permalink) Old 06-21-2011, 10:44 AM
Come on people order some parts! Who doesn't like discounts!?
I want the Eaton posi, 3.73 Yukon gears, and the master overhaul kit. Thanks
post #9 of 44 (permalink) Old 06-21-2011, 04:33 PM Thread Starter
Vendor
There are only two sets of 3.23 gears available along with the reluctor ring. $225.00 is the best I can offer on that size since they are on their way out.
Interestingly enough, every order thus far as been without discount. Either the customer didn't want to wait for others or they need their parts quickly.
[email protected]
post #10 of 44 (permalink) Old 06-21-2011, 07:25 PM
Add me for some 373 gears and abs reluctor.
norcalsupersport209 is offline
