Aluminum Coolant Tank Resevoir - Chevy Impala SS Forum
post #1 of 101 (permalink) Old 04-29-2013, 05:25 PM Thread Starter
Aluminum Coolant Tank Group Purchase
Note - I know this is a lengthy read, but I want to try and share what I currently know and possibly answer any questions you may have up front. If anything else comes to mind, please ask and I will try to get an answer. Joe is a Ford Guy (We wont hold that against him :>) ) but I will see if he can create an account here and answer you questions directly.
I stumbled across a company that makes an Aluminum Coolant Tank for our cars. They are a really nice option for the owner that wants something different than that ugly, hard to clean plastic tank. I have been in contact with Joe at WWW.THEFUSIONSOLUTION.COM about his Aluminum version of the Coolant Tank that would work on 94 -96 LT1 engines in the Caprice, Impala, Roadmaster and I think the caddy's that run the LT1 engine. This tank will also work in the L99 equiped Caprices.
Joe has made a handful of these tanks and his Father currently has one on his Impala with no issues. There are a few concerns I have that I wanted to share with the forum and let you know what we are thinking at this moment. Please understand that Joe seems like a Quality Guy and very concerned about anything he puts his name on. There currrently are not many of these tanks on the road and I had some concerns as I'm sure you may too. If we do this, we want to make sure that everyone is happy and pleased with their purchase.
I have a few concerns that I spoke to Joe about and want to be sure I share them here and as we go forward.
1) Joe is a 1 man Show and works a regualr job and will be doing this on the side. Depending on order number, it may take a while to produce. It does sound like he would be willing to work with us on Payment and may just require a small deposit to lock you in. But that still needs to be discussed.
2) Cost is currently $160 plus ship cost. I would like to see what kind of pricing he can work up for us. I'm hopeful we could get something in the range of 20% off depending on what numbers we have. Again this still needs to be discussed. But if you look at the cost of GM's current offerings, the stock tank is in the $80 range, then the extra cost for the amount of craftsmanship and materials involved to make one of these tanks, the cost sounds very reasonable.
3) He has made a few and has had one on his Fathers car for quite some time with no issues. However, his dad's car is not a daily driver and I want to be sure there are no issues with these for those that drive their car frequently. Joe's shop is about 2 hours away from me, so I am going to use my car as a tester and commit to driving it daily for a month. We will then have a good idea if there are issues...which I doubt there will be.
4) My concern was that the stock Plastic tank may have "baffeling" in it that would affect how the system operates. Joe assured me that what appears to be "baffeling, is merely for structural purposes of the tank. His aluminum tank is completely open on the inside which could certainly make cleaning and maintaining the system much easier.
5) There is no coolant level sensor on his tank. If you are familiar with the stock tank, then you know this feature is molded into the tank. So if this is a concern, you may not want to consider one of his tanks. He did assure me, that the sensor wire being unplugged does not cause any issues with the car other than you have to check the level manually.
6) He was using a supplier for the Filler neck who no longer makes these. He currently has enough in stock for about 6 more tanks. He has been in touch with another supplier and should have something available as we move forward.
7) No Markings on the tank for Full and you will need to pull the cap to "eyeball" the coolant level. He said 1/2 way is about right for the tank.
8) No 2nd port for cars with a hose to the radiator. This could be an option, but my understanding is you could just cap off the extra port on those.
There are certainly some plus's to his Aluminum tanks.
1) The fit and look is amazingly stock, yet the aluminum looks much nicer than the Plastic Tank and it will probably outlive your car.
2) Cleaning of the inside would be very easy wirth no baffeling in the way.
3) He could also make the fittings with AN Connectors for those that wish to use AN lines instead of Stock hoses. He would also be able to place the port in a different location other than stock if that fits your plans better. Whether this would be an extra charge or not would have to be determined, but at least you have that option that you would not have with a plastic tank.
4) Bottom line, they are just way too cool and very unique for our cars. Not many people at the car show would have one. .
Check his website for some Pics of his tank for our LT1/L99 cars. I also included some pics that he sent me. So....what do you think? Are you interested in something like this for you car(s)? Please respond here and stay tuned for more information in the next month or so.
ALSO - He is also at making a Power Steering Resevoir Tank for our cars that would look stock and mount as stock. Could match nicely with the Aluminum Coolant tank and the AC accumulator. A Washer Fluid bottle will not be made as the fluid would not work well with the Aluminum. He said he considered one out of stainless, but that would be way too costly.
Thanks.....
post #2 of 101 (permalink) Old 04-29-2013, 06:52 PM
strokedimpala's Avatar
tank
I would be interested in the overflow and power steering reservoir.
Thanks Paul.
1996 ss 396 lt-4 competition longblock golen engines.custom hood,bumpers,spoiler,20\"billet specialties wheels.3.73.speedtech performance upper and rustic lower control arms.power performance motorsports frontend.body bushings,frame and floorpan painted.tce 14\" 6-piston front kit wit 4-piston 13\"kit in rear.
stainless quad-1 headers w/3" stainless exhaust.
fully painted undercarriage,w stainless bolts everywhere.
strokedimpala is offline
post #3 of 101 (permalink) Old 04-29-2013, 06:54 PM
96SSbbb's Avatar
Id be in for both, but with stock connectors.
ISSCA# 930
96SSbbb is offline
post #4 of 101 (permalink) Old 04-29-2013, 09:03 PM
Dropped Fullsize's Avatar
I'd be interested in all of the items listed and have no problem with providing a deposit if necessary.
My reservoir tank is brand new, but I would be willing to go with an Aluminum tank. Can you please email me some more pics? The engineer in me is already thinking of things that might be able to get modified in order to make things functional.
On my way to PM to send you my email address.
Dropped Fullsize
82 El Camino
95 Impala
00 Crew Cab Chevy Dually
01 300M
02 Silverado
11 Crew Cab Silverado
_______________________________________________
Dropped Fullsize is offline
post #5 of 101 (permalink) Old 04-29-2013, 09:58 PM
Chris96Coprice's Avatar
I am interested in a PS res depending on what it looks like.
Thanks
Chris
PS that link doesnt work you posted.
Fish- ISSCA #2478
96 BBB Impala SS-it has some work done.
My SS Build Thread
1st Place-2013 & 2014 ISSCA AutoX Prepared Class Winner
2015 AutoX Modified Class Runner-up
2016 AutoX Modified Class Winner
2017 AutoX Modified Class Winner
2019-BOI Pittsburgh, PA
Chris96Coprice is offline
post #6 of 101 (permalink) Old 04-30-2013, 01:24 AM
1phastss's Avatar
http://www.thefusionsolution.com/
CarISSMA (Carolinas Impala SS Motor Association) President
1991 White LSX Wagon - (HIS) A.K.A "The Abomination" / Reaper
1991 White SS Wagon - (HERS) SS Nose-SS Wheels-3.23 POSI-Clear Corners-Silverstars-Tinted Windows
ISSCA Member #2499
1phastss is offline
post #7 of 101 (permalink) Old 04-30-2013, 06:46 AM Thread Starter
Thanks
Chris
Sorry about that, it was a Cut n Paste from Word so the verbage was right, the link was broke. I cant go back and Edit my original Post....not sure why, but the link 1PHAST posted should get you to his site. This link should take you directly to the section under his "PROJECTS" listing that has a few pics of the tank.
http://thefusionsolution.com/#/94-96...pansion-tank-/
As for the PS tank, I'm anxious to see pics myself. He mentioned he has one in design but not finished yet but intends to have it look and fit like stock.
post #8 of 101 (permalink) Old 04-30-2013, 06:59 AM Thread Starter
Glad you like it. I have a few more pics he sent me but they were just close up of the mounts. I will post up what I have that I did not include in the original post for others to see.
Here you go....
post #9 of 101 (permalink) Old 04-30-2013, 07:04 AM
ocala's Avatar
Would it but possible to design the tank so it would accept the low level sensor? If so I'd be in.
Sent from AutoGuide.com App
ocala is offline
post #10 of 101 (permalink) Old 04-30-2013, 07:22 AM Thread Starter
I guess anything is possible, but in the discussions I had with him, dont think it will happen and I wanted to be sure to mention that.
For me, its not a big deal since I just try to check the fluids on my own and not rely on an Oil or Coolant level sensor. But I wanted to make sure people were at least away of it as I knew some might have issue with this. But really, unless you got a leak somewhere, it should stay pretty constant. I dont believe in the 14+ years I owned my Caprice that light ever came on. the only time it did is when I would flush the system and be in the process of filling and bleeding the air out.
One of the problems could be cost vs need. Is there a part that is even available that could be added to a metal tank and function as the stock unit does using the stock sensor? There may be, but from what I was told it does not sound like something he persued any further. I will ask him about it again, and hopefully he can respond directly to your question here.
