Removal of shifter and cables. - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 09-22-2015, 12:20 PM Thread Starter
Hello. How about a rundown on removing the floor shifter from a 96 SS in particular the brake release cable and the trans shifting cable as I am going to sell it to other Caprice/Impala owners prior to junking the rest of the car. I have already removed the shifter handle and the console. Thanks Again, Norm.
96 SS DGGM, original owner, purchased 1995, 194K miles (sep 13), SLP 2400, Transgo Kit, Eaton Posi, 3.42 gears, Be Cool Radiator, B&M Trans Cooler w/fan, Bryan Herter Programming, 160 Thermo, Underdrive Pulley. 96 SS Black, 72k miles (sep 13), all stock., purchased 2013, Worcester, Massachusetts.
fasterdaddyfaster is offline
post #2 of 2 (permalink) Old 09-24-2015, 12:37 PM
Blue Wail's Avatar
Use a screw driver and pop the cable off the shifter mechanism.
Then squeeze the sides of the plastic "hook" that holds the cables to the shifter base.
Pull the cables out.
Nab
Blue Wail is offline
