shift from park problem - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 10-10-2015, 06:46 PM Thread Starter
impalassdude's Avatar
Send a message via AIM to impalassdude
i have a 94 impala that i installed the blazer floor shifter a few years ago now im having problems at random shifting out of park it wont release.can i bypass the shift from park solenoid?
http://www.youtube.com/watch?v=GRqsOvpSxA4
President of SoFASST
05-06 1st place 94 class nationals
05 3rd place sound off
06 3rd place autocross
also as seen on the ITT commercial
95 caprice wagon impala clone
96 dggm impala ss
94 bbb impala ss
check out SoFASST on facebook
impalassdude is offline
post #2 of 9 (permalink) Old 10-10-2015, 09:47 PM
TGO
How do you know it's the solenoid? Sounds more like a shift cable binding or otherwise worn out.
TGO is offline
post #3 of 9 (permalink) Old 10-10-2015, 10:01 PM Thread Starter
Checked that first.cable is fine.
post #4 of 9 (permalink) Old 10-23-2015, 08:19 AM
If it's configured the same way the stock 96 B-body park solenoid is, yes. That solenoid is normally-off, and energized when the car is started. Putting your foot on the brake momentarily turns the power off allowing you to pull the shifter out of park.
I had a similar problem with our 96 SS. It was getting to the point that I was afraid I'd be stranded at work with the stupid thing not coming out of park. I simply unplugged the park solenoid, and haven't looked back. So it can't hurt to try in your instance.
Gene Beaird
95 DGGM SSSS, HAIL
96 BBB SSSS, HAIL 'WarPig'
2012 9C1 Caprice (my DD)
2010 Tahoe PPV (her DD)
92 B4C 1LE Camaro
85 Firebird, SCCA CP Solo II - 310 cu. in. LS1/TH350/Moser 9"
95 381 LT4/6SP Z28 Vert - 405 RWHP (Her Car)
Pearland, Texas
Gene Beaird is offline
post #5 of 9 (permalink) Old 10-23-2015, 10:29 AM
angelo's Avatar
Do you think the plastic got bent from the heat like in the pic in this thread ?
https://www.impalassforum.com/vBullet....php?t=1269082
-ALF out...
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #6 of 9 (permalink) Old 10-23-2015, 11:24 AM
Z09B4U's Avatar
For testing only
There are two solenoids on the brava shifters.
One is connected to ignition power (Dk green/white cavity B). This one locks the shifter when the key is off and unlocks when you have the car running.
The second works backwards to the first. (Lt green/black cavity E) It is locked by power and released by power turning Off. It is usually wired to the old shift solenoid. This is the cruise control brake switch.
You would check cavity B for power when the car is running and that power to cavity E goes off when you hit the brakes.
This means you might have a problem with the cruise/brake switch or a broken connection to the B circuit.
Check cavity F (black) for a good ground.
For temporary bypass testing take the shift boot off.
On the right side there is a manual override lever(white). Pull it towards the shifter (left) to get out of park. At the base of this lever is a white disk that goes right when the electric release works. The manual override also pushes it right. If you place something like a cable tie in this area to block the disk returning to the left you defeat the shift lock.
These two solenoids on the brava shifters are known to fail so if your power is right you might need a new shifter.
Different year shifters have different wire colors and people install this shifter in different ways so it is hard to help over the internet.
Please fix the shiftlock.
Z09B4U
Z09B4U is offline
post #7 of 9 (permalink) Old 10-23-2015, 07:18 PM Thread Starter
due to work i haven't had a chance to check this out but as gene b said i keep getting stranded at places because i never know when its going to happen.might start dozens of times then all of a sudden shifter button wont engage .i keep the car running and keep wiggling shifter and it has always come loose but need to get this fixed.going to try unplugging the solenoid first at steering column.thats where the wires that z09b4u was talking about coming from the shifier.
96 dggm impala ss
94 bbb impala ss
post #8 of 9 (permalink) Old 10-23-2015, 11:13 PM
Your brake switch may not be breaking the circuit for the press brake to shift function.
post #9 of 9 (permalink) Old 11-04-2015, 12:04 PM Thread Starter
i finally got to check it out today.i unplugged the shift from park solenoid and seams to be fine.will take it for a drive later but works perfect so far.thanks everyone for the help!
96 dggm impala ss
94 bbb impala ss
