96 Impala BBB window and door lock issues - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 11-01-2015, 09:19 AM Thread Starter
kiefer9699's Avatar
I am having a few issues on my 96 bbb. 3 windows are off track or slow to go up and down, and door lock issues as well where one door only opens from the inside, and other door does not lock at all. Also antenna works fine for signal, but does not retract. I am mechanically inclined, but usually intimidated with jobs like glass and door panels. Can I tackle these issues my self, and how do I fix them, sounds like these are common problems on these cars. Thanks
1996 BBB, K&N Intake, FB/HP Delete, AIR Delete,Billet Resonator Insert, TB Bypass, TPIS Air Foil, F Body EGR, Moroso 8mm Wires, NGK Iridium Plugs, HT 160 Thermostat, Magnaflow Hi Flow Stainless Cats, Pypes 2.5" X-Pipe, Dynomax VT Mufflers, Dynomax 2.5" Tail Pipes, KYB Shocks. BMR 1 1/4" Front Sway Bar, Rear GM Upgraded Lower Control Arms, Nitto 450s, PCM4Less 93 tune, Oil Cooler Delete.
kiefer9699 is offline
post #2 of 3 (permalink) Old 11-01-2015, 01:37 PM
Get two rollers for each window, and start replacing the old ones. You can find instruction on the forum. If they are sticking, check the inside wipe for roll under when lowering the glass.
Since you are going to have the door panels off, check the linkage for the locks. You may have one disconnected.
The cable for the antenna is still available. Here is were you can find one: http://www.antennamastsrus.com/GM/Ch...01991-1996.htm
Instruction for repairing the antenna are on the forum as well. The only "trick" is to position the small white gear correctly. The filled tooth goes between the 4/5 o'clock position with the antenna up.
post #3 of 3 (permalink) Old 11-02-2015, 08:40 AM Thread Starter
kiefer9699's Avatar
Thanks for the input
