How to remove passenger air bag cover? - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 11-14-2015, 02:26 PM Thread Starter
I want to remove the cover because I want to customize it. Is it attached to the air bag itself? How hard would it be to remove the cover?
JRiggsIV is offline
post #2 of 2 (permalink) Old 11-14-2015, 02:38 PM
The AB lid is part of the dash pad. You need to remove the dash pad, flip it over and on the bottom Side of the dash are 3 mesh straps that mount retain the lid to the dash pad if the bag deploys. There are a couple of nuts that sandwich the mesh straps to the bottom of dash with some metal brackets. Once unbolted the lid will push out of the dash pad.
