window slow going up, fast going down - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 12-03-2015, 06:18 PM Thread Starter
My car sat for nearly two years outside, waiting to get an engine rebuild. When I got it back, a lot of hoses needed replacing. My drivers side window goes down slowly, in fact, it stops after going down about an inch. I hit the switch after a minute and it goes down another inch. Then again. Once it gets close to halfway down, it comes down fine. Going up is no problem. Likely this is the motor?
Alchemist is offline
post #2 of 6 (permalink) Old 12-03-2015, 07:40 PM
Spaceman Spiff's Avatar
Send a message via AIM to Spaceman Spiff
i just bought a '95 9C1 with a similar issue. it'll go down a little, then a little more, but stops about 2/3 down. doesn't like to go up. you have to pull it up, while holding the switch.
I'm going to take the door panel off this weekend and have a look.
I ordered an ac delco motor from rock auto, along with new rollers. it was cheap enough that if it's not the problem, i could just hold onto it.
95 DCM WX3. BONNY'S, CAMARO CLUSTER, BLAZER CONSOLE/FLOOR SHIFT, BLAZER OVERHEAD MONTE CARLO WHEEL, 3.73'S, EXTENDED ARMS, TRI-Y'S, NO CATS, X PIPE, PRO SHOOTOUTS SMOKED HEADLIGHTS, HIDS, RED BOWTIE
'95 DGGM 9C1, winter beater.
Spaceman Spiff is offline
post #3 of 6 (permalink) Old 12-04-2015, 10:43 AM
Check your interior seal along the bottom of the glass. It may be rolling under, and jamming the window. I do not have a cure for the issue, but taking pressure off of the glass, or lubricating it with dry lube may help. Cleaning the glass and seal may also help.
post #4 of 6 (permalink) Old 12-07-2015, 07:15 PM
1FAST94's Avatar
Buy a can of spray silicone lube (it's clear) and spray the front and rear tracts that the glass rides in.. Window down and then up and down a couple times and then soak again. It works great.
Mike Harris
B-BODY PERFORMANCE
Dayton, Ohio
10.43 @126.95 @ 3800 lbs.
http://www.youtube.com/watch?feature...&v=a8dYCl2cAdM
1FAST94 is offline
post #5 of 6 (permalink) Old 12-08-2015, 12:40 PM
Blue Wail's Avatar
With cars approaching 20 years old, things like this wear out
espcially DS window which is used the most.
Count on replacing the regulator motor soon in any of these cars.
Nab
Blue Wail is offline
post #6 of 6 (permalink) Old 06-26-2016, 03:34 PM Thread Starter
Nab
Well, got lucky. It was both window sliders jamming in their tracks. Replaced them with the round nylon ones and a good bit of WB grease and like new again. All's well. Thanks Blue Wail.
