A solution for broken door panel clips - Chevy Impala SS Forum
 4Likes
  • 1 Post By wagon64628
  • 2 Post By wagon64628
post #1 of 8 (permalink) Old 04-11-2016, 01:23 PM Thread Starter
wagon64628's Avatar
Had to remove my front door panels to replace both power mirrors and driver side window channel. Once door panel was off, discovered the bottom three metal panel clips were broken off the door panels. My solution was to drill 4 holes per clip down lower in the plastic mounts and secure the metal clips with small zip strips. Was pretty easy to do and the clips are firmly reattached to the door panel, hopefully cuts down on some rattles. Attached are some pics, hope this helps someone with similar problems.[ATTACH]Click image for larger version
KingsKrew likes this.
95 Light Adriatic Blue LT1 Caprice Wagon
wagon64628 is offline
post #2 of 8 (permalink) Old 04-11-2016, 01:25 PM Thread Starter
wagon64628's Avatar
post #3 of 8 (permalink) Old 04-11-2016, 01:27 PM Thread Starter
wagon64628's Avatar
Stupid iPhone would only allow one pic per post.
KingsKrew and CHILNLO like this.
post #4 of 8 (permalink) Old 04-11-2016, 02:52 PM
CHILNLO's Avatar
No movement from the clip? Otherwise a good idea.
1996 Chevy Impala SS
Cali-SS
CHILNLO is offline
post #5 of 8 (permalink) Old 04-11-2016, 09:21 PM Thread Starter
wagon64628's Avatar
No they are remarkably solid, initial idea was mechanics wire, but went with small zip strips. Thought they would be less like to tear through drilled holes. Even if they were a little loose doing this method, loose is still better than not attached at all!
Got the drivers door panel reinstalled and it is very solid to the door. Hopefully will be many moons before I have to remove it again.
CHILNLO likes this.
post #6 of 8 (permalink) Old 04-14-2016, 09:46 PM
bigblackss's Avatar
wow good call ill have to give that a try
94 BBB SS
bigblackss is offline
post #7 of 8 (permalink) Old 04-15-2016, 06:22 AM
Nice solution, that's thinking outside the box.
With similar break I just used some epoxy to hold the metal bracket to the panel and that's been working. If the epoxy ever fails, I may go with your solution. Thanks for sharing.
post #8 of 8 (permalink) Old 04-15-2016, 08:20 AM
350
350's Avatar
Send a message via AIM to 350
That's a good idea, I think I broke a few more when I swapped my window motor last summer.
95 DGGM SS. Cam and headers, boring stuff, classic tags, garaged
15 Durango R/T AWD, Fiat with a Hemi and 8 gears
15 Charger SXT AWD
350 is offline
