Turn Signal Upgrade Or Retrofit? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 11-01-2016, 11:54 PM Thread Starter
I've noticed that the turn signal stalk assembly on this 94 Fleetwood is pretty much the same one as on an 80s Cavalier I unfortunately used to have knowledge of. It's crunchy, flexy, vague and really doesn't befit a big car.
Is there any way to upgrade this turn signal stalk mechanism or retrofit the car with another mechanism from a later/different car?
Working on a 1994 Cadillac Fleetwood Brougham...
CB700S is online now
post #2 of 4 (permalink) Old 11-02-2016, 11:59 AM
Z09B4U's Avatar
It is a saginaw
These columns go back to the 70's and can be found on AMC and Chrysler products. They mostly use the same two switches. One has cornering lights one does not. They do wear out.
My personal experience is that a new quality switch will make a click you can feel when you push it all the way. You will feel a click when the canceling cam pushes it off after a turn. I would not call the feel
Z09B4U
Z09B4U is offline
post #3 of 4 (permalink) Old 11-02-2016, 12:41 PM Thread Starter
The switch does click, but it takes effort and it's not really precise in how it works. Yeah, I know it's a Saginaw column - but you'd think someone would have come out with a better feeling switch for the thing in all those years.
post #4 of 4 (permalink) Old 11-02-2016, 02:26 PM
91ss's Avatar
Yeah, definitely agree with 700. Every GM i've owned has/had that 'crunchy' non smooth travel until it clicks. Like it might just needs a better grease for plastic on plastic movement. It's more like a chatter than a glide.
91ss is offline
