Factory style replacement door panels - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 01-17-2017, 12:21 PM Thread Starter
My driver side door panel has cracks and I have been searching around for a new replacement but can't seem to find any. Does anyone sell new replacements? (95 impala)
rotiboy is offline
post #2 of 5 (permalink) Old 01-17-2017, 01:23 PM
Short answer..No or at least none I've seen. Have seen some aftermarket fiberglass ones though that would need some work.
Your best only option may be used panels or try to repair yours. There is info here on how to take these apart and maybe you could use good parts from other panels? At least that's my plan at some point with spare panels I have from other cars. I always cringe every time I need to remove the front panels cause they are so flimsy and already have some issues.
post #3 of 5 (permalink) Old 01-17-2017, 01:43 PM Thread Starter
thanks for the reply. i will take your advice and try some repairs
rotiboy is offline
post #4 of 5 (permalink) Old 01-17-2017, 03:03 PM
ProTools4's Avatar
someone needs to step up and make them!
NotoriouSS Tad
17' Betty - Cam6 2.0T 2LT RS HMB
ProTools4 is offline
post #5 of 5 (permalink) Old 01-17-2017, 03:51 PM
I have posted a number of times on repairing the door panels with MEK. I have recently started using fiberglass screen to reinforce the repaired cracks, then coating them with a scrap plastic and MEK paste.
