Help ID Heat SKink - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 05-08-2017, 06:55 AM Thread Starter
juniorwatson's Avatar
Help ID Heat SKink
Folks,
While doing some interior this past weekend, I had the lower dash (Correct name for this piece/Radio bezel trim?) removed for ease of assembly.
When in there I noticed a heat sink assembly around the LH knee area, and before I start looking around I was hoping someone will be able to help in identifying what this is?
Comments, suggestions?
Thanks!
juniorwatson is offline
post #2 of 3 (permalink) Old 05-08-2017, 09:09 AM
Check Pic - Maybe More Response(s)
EU 'No Entry' sign with 1 browser, green mountainous box with another.
post #3 of 3 (permalink) Old 05-08-2017, 10:37 AM
Z09B4U's Avatar
Without a picture my first guess is the Panel lamps dimming module with wire colors yellow, gray, and dark green.
Second guess on a car with daytime running lights diode with wire colors dark blue and tan.
Z09B4U
Z09B4U is offline
