wood and leather shift knob for 6 speed - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 10-02-2017, 07:13 PM Thread Starter
V8killer's Avatar
Been browsing ebay and amazon and I have yet to find one that either I liked or that it fit the m16 thread pattern.
Show me your knob!!!
STOLEN ON JUNE 8TH OR 9TH 2003 FROM TACOMA,WA
ISSF MEMBER #282
94 9C1,SS clone,DCM,SSRI,HA/F-body sway bars,3.42's Bonnies,floorshift,Stillen front,Smoothy rears,billet grille,white face Z-28 dash, Dynomax mufflers,Tri-Y,eibach,J&M control arms,NOS 100 shot,MSD digital+6&coil,MSD super conductors,metco safety loop,Dynotech driveshaft [email protected]
V8killer is offline
post #2 of 11 (permalink) Old 10-03-2017, 08:01 AM
ocala's Avatar
I have this one. It will need so modification of the shift lever, possibly welding, but it will all be under the boot.
ocala is offline
post #3 of 11 (permalink) Old 10-13-2017, 08:18 AM Thread Starter
V8killer's Avatar
**** i thought this would be a direct fit, how much modification is needed? this is the exact one i'm about to get
ISSF MEMBER #282
V8killer is offline
post #4 of 11 (permalink) Old 10-14-2017, 12:01 PM
TGO
They sell adapters for the threads.
I think the issue is that you want wood.
Also if you go aftermarket for your shifter (like MGW) you have at least two thread options to choose from.
Or like above...corvette shifters aren't threaded. They have a set screw in the side that keeps them in place.
2001 Corvette ZO6
1995 Impala SS - H/C/I - BBB
TGO is offline
post #5 of 11 (permalink) Old 10-16-2017, 01:54 AM Thread Starter
V8killer's Avatar
I bought this but it's not threaded. It's a C6 corvette knob.
Can anyone tell me if there's an adapter I can use to install this on my threaded shift lever?
https://i.ebayimg.com/images/g/DmAAA...l~M/s-l400.jpg
ISSF MEMBER #282
V8killer is offline
post #6 of 11 (permalink) Old 10-16-2017, 10:48 AM
IDK what size that Vette shift knob is but modifying the end of whatever shift stick, or even making a new one, is doable.
I have a Tremac knob that came with a few "adapter" threaded inserts so it could be used on a few different size threaded sicks
If the Vette one is not threaded but just has some shaped end with a flat side for a set screw than I would think a stick could be "modified" (machined) to accept it
BALLSS is online now
post #7 of 11 (permalink) Old 10-16-2017, 09:41 PM
ocala's Avatar
The Vette shifter shaft. I?m thinking of cutting the end off and welding it to the regular shift lever. Or I could cut the lever and GLUE the knob on it...
ocala is offline
post #8 of 11 (permalink) Old 10-17-2017, 12:34 AM Thread Starter
V8killer's Avatar
Yeah the knob is not threaded, and it's some sort of plastic/composite
I can epoxy it in place but I would rather have it not be that permanent in case I need to take it off (shift boot, console removal etc)
ISSF MEMBER #282
V8killer is offline
post #9 of 11 (permalink) Old 10-18-2017, 10:14 AM
TGO
I've heard of people gluing it.
Does it fit over the threads? If so you're good. Just drill a hole to use the set screw in the side.
There used to be a company that sold threaded C6 knobs for use on the C5. I guess if you've got some patience and a the right size tap you could do it yourself too.
Or just buy a C6 shifter assembly and use that.
2001 Corvette ZO6
TGO is offline
post #10 of 11 (permalink) Old 10-20-2017, 05:46 PM
eagle-co94's Avatar
This is the shifter that I use:
I'd suggest the smaller one as the larger one is huge. I bought this shift knob over a decade ago and it still looks great. I had to drill and tap it myself. Not a big fan of wood shift knobs.
James
"Power tends to corrupt, and absolute power corrupts absolutely." Lord Acton
96 BBB SS - BBHP #123-4.56
11 9C3 PPV ~ 67 Caprice 4DR Hardtop ~ 08 Tahoe PPV
10 Challenger SRT8 ~ 08 300 SRT8 ~ 85 Austin Mini - RHD on 10's
ISSCA #1830...expired
eagle-co94 is offline
