Interior plastic trim screw replacement? - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 11-17-2017, 01:00 PM Thread Starter
juniorwatson's Avatar
Since I've recently done the interior all over, and cleaned up all of the gray plastic pieces of trim, primarily the rocker panel covers, and then the rear pieces which mount on each side of the rear seat, I'm wondering if anyone has found any replacements to clean up the interior.
I didn't see anything on McMaster Carr, and have not yet looked at Camcar Textron which I've been told are a big supplier for automotive manufacturers, and other industrial manufacturers.
While searching the archives I've found this P/N: 11515187. I see a PKG available on eVilbay, and $2.00 isn't horrible (Plus shipping costs), but I'd prefer 18-8 or 304 stainless.
juniorwatson is offline
post #2 of 6 (permalink) Old 11-17-2017, 01:07 PM
gbhs72's Avatar
Junior, check this out. He has a door sill kit in stainless. Chevrolet Body
Mark: Snowman-33
gbhs72 is offline
post #3 of 6 (permalink) Old 11-17-2017, 02:34 PM
I went to my local Ace Hardware and they had them in stainless steel>
BH tuning, Transgo shift kit, Eaton posi W/ 3:73 gears, EDGE 9.5" 3000 stall , BMR rear lower control arms. BMR front and rear sway bars Hotchkis springs, CIA trans crossmember; 1.6 Pro magmuim RR; CIA budget headers w/ high flow cats; 2 1/2" cat back with X pipe; chrome dual cone CAI, 52mm throttle body, 30lb SVO injectors, Wilwood brake calipers, Power Stop drilled and slotted brake rotors, Bilstein shocks. Gary's 2 relay headlight harness. Gary's battery relocation harness
my95ss is offline
post #4 of 6 (permalink) Old 11-17-2017, 03:48 PM
gbhs72's Avatar
Smoly Hoke!!!! I just looked at some of those on EB. The bend over price was $2 each. No thanks. One showed a 10 pack for the $2 The ones I posted in SS were $15 for 24. That seams as if it's fair amount, IMHO
Mark: Snowman-33
gbhs72 is offline
post #5 of 6 (permalink) Old 11-17-2017, 05:09 PM
Check with MMS Stainless and see what they may have....
MMS & Accessories, Inc.
I have a bunch of stuff from them like their FRont end Hardware kit and some other covers. They make a lot of B-Body specific stuff and even braces like the "Buick Brace" and the Firewall Braces.
Very good quality stuff and their prices are/were very good.��
post #6 of 6 (permalink) Old 11-17-2017, 06:01 PM
Most any/all varieties of trim hardware is available by the bag,or box from NAPA quite reasonably....
