Footwell Light Bulb Removal - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 01-21-2018, 09:18 PM Thread Starter
What should be the simplest bulbs to remove are baffling me. How do you get these bulbs out? I can't seem to get them to budge. I've replaced the rest with LED and just have these 2 foot well ones to do.
96 Impala SS - 20" American Racing Novas, K&N Gen II, Eibach, etc.
86 Buick Grand National
87 S-15 w/350
99 BMW 540i 6Speed
GearHead is offline
post #2 of 5 (permalink) Old 01-21-2018, 11:16 PM
Your filter thread and last post
Push in and turn counterclockwise. If they are stuck, a shot of WD40 or similar should help. This assumes they are bayonet mount. If a wedge type, just pull.
grandpas wagon
grandpas wagon is offline
post #3 of 5 (permalink) Old 01-22-2018, 07:42 AM
I believe they are wedge type. Put a piece of something around the bulb in case it breaks.
post #4 of 5 (permalink) Old 01-22-2018, 10:49 AM
Z09B4U's Avatar
They should be wedge type (194?).
A very large set of needle nose pliers with medical tubing on the jaws is one way. Very sticky tape applied to the bulb for grip also works. I have a toy(key-chain) set of slip joint pliers that work well.
Worst case the bulb breaks and you pull it out by the filament wires.
Hope you have found LED replacements with a wide angle as a spot of LED light on the carpet looks weird.
Z09B4U
Z09B4U is offline
post #5 of 5 (permalink) Old 01-22-2018, 02:16 PM
Haha that looks like the tiny grain o wheat type in the Fleetwood doorpull. I played hell getting that out.
