Stock light gray leather seat cover replacement/repair - Chevy Impala SS Forum
 3Likes
post #1 of 12 (permalink) Old 02-16-2018, 10:08 AM Thread Starter
What is the GM part number for the stock leather seat covers (light gray) used on a 96 Impala SS? Looking for the drivers side cover (seat, not the seat back). Are there aftermarket options out there? EBay? My original cover is developing a rip right in the middle of the cover. Are there repair options out there?
96bliss is offline
post #2 of 12 (permalink) Old 02-16-2018, 11:46 AM
4x4high's Avatar
Streettrends offers them and pretty cheap too.
kenn82draw likes this.
1996 DGGM Impala SS
4x4high is offline
post #3 of 12 (permalink) Old 02-16-2018, 12:02 PM Thread Starter
What's involved in the replacement of the seat bottom? I assume taking the seat out of the car makes things easier? Other than the seat cover, anything else needed (such as any clips to hold the seat cover down)?
96bliss is offline
post #4 of 12 (permalink) Old 02-16-2018, 12:22 PM
kenn82draw's Avatar
https://www.streettrendsinc.com/Seat...holstery-each/
BBB 95 SS - Purchased 11/11/2017
Blue 94 9C1 - Sold in '06 due to emissions
kenn82draw is offline
post #5 of 12 (permalink) Old 02-16-2018, 01:03 PM
4x4high's Avatar
Hog rings and hog ring pliers would be all that is required as far as anything special.
1996 DGGM Impala SS
4x4high is offline
post #6 of 12 (permalink) Old 02-16-2018, 01:29 PM
you likely would want to add or replace seat bottom foam. Upholstery supply places have foam is various thickness
the spring bottom may need some attention if a spring broke. From my understanding these are not available new anymore. The springs themselves can be fixed. Most upholstery shops deal with that all the time
post #7 of 12 (permalink) Old 02-22-2018, 03:19 AM
the ST cover they sell is slightly lighter than our interiors. if you are trying to do it low budget you reuse the hogrings and get a used foam from a roadmaster base model passenger seat bottom and take the springs too if you are repairing that too
Nor*Cal INC - San Francisco, California
1996 Impala SS
1996 Caprice 9C1 6 Speed /4.56s
1995 Caprice 9C1 6 Speed /4.10s
eze415 is offline
post #8 of 12 (permalink) Old 02-22-2018, 11:15 AM
Z09B4U's Avatar
There should be a thread about the seat repair. The one about cutting down the drivers seat from 60% to 40% also would be good reading.
I used a donor caprice passenger seat for parts. The Impala drivers seat had serious issues. Stretched springs, bent rods, (that the springs connect to) bottom foam was cut by spring support, and the foam was compressed.
I replaced stretched springs, straitened the rods and added donor rods for two rods a side.
If my memory is correct I was able to add a spring on each side?
A heavy polyester layer over the metal spring support. (old school used burlap) Then some single layer cardboard.(both extra to prevent further foam damage).
New foam on top of the old seat foam.(1/2 to 1"?) All donor foam is 20+ years old now.
I open the hog rings with needle nose pliers and close them with slip joint pliers. I used a loop of aircraft(1/4) cable to stretch the good springs to hook them back on the seat. Gloves and safety glasses are worth putting on. If a spring gets loose it can do damage.
A trick I saw on TV is to place a heavy sheet or plastic bag over the foam. It lets the cover slide over the foam easier. Near the end pull out the plastic. This is great for seat backs. Modern seats covers have Velcro spots that make this even harder without the plastic.
1slow96 and kenn82draw like this.
Z09B4U
Z09B4U is offline
post #9 of 12 (permalink) Old 02-22-2018, 02:08 PM
you'll find suchlike in the FWB section. Keywords might be: SStealth or Riviera Console. Not too entailing. flip seat, unwrap the "10%" center portion lol, hacksaw the little support tube(s) cut and fold the remainder under. ya ain't never gonna see the modded area with a console of any type.
Or, get a JY pass seat cover. There again, never gonna see the original right side holes.
I would never do such as it defeats the purpose of having a "true 6-passenger in comfort" capacity without forced to submit to a disgusting reprehensible minivan or SUV. (sorry was that out loud)
post #10 of 12 (permalink) Old 02-22-2018, 05:47 PM
Z09B4U's Avatar
Opinion respected.
96bliss has never taken apart a Impala seat. Pictures are said to be worth a thousand words and if there are pictures of someone taking a seat apart the pics should help. I wish I had taken pictures the last time I took one apart. Things like removing the clip on the seat back adjuster are easier to show than explain.
Z09B4U
Z09B4U is offline
