Door Switch Panel Lettering - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 04-05-2018, 06:06 AM Thread Starter
any body doing this any more? I need complete set for front and rear doors,since I changed interior door panel color
when you don't know what to do,do what you know
ahoora is offline
post #2 of 7 (permalink) Old 04-05-2018, 05:36 PM
Not sure but check this thread for some info....
https://www.impalassforum.com/vBullet...lettering.html
....check the link in I believe post3. You could buy new door bezel's for the front for about $25. I have a Black Set from them and the quality is VG.
post #3 of 7 (permalink) Old 04-06-2018, 03:03 AM Thread Starter
unfortunately I changed the interior color of my car to lighter gray,so the new one does not work,but there are some other ideas there that might work ,thanks for reply
ahoora is offline
post #4 of 7 (permalink) Old 04-06-2018, 10:17 AM
gbhs72's Avatar
ahoora, I haven't used any of these but have looked into this in the past. Maybe something here.
Graphics - Superior Restoration Products
screaming aero graphix
Control Button Renu
SGK-GM Button Graphic Kit
I have also thought about decals for model/RC cars. I'm hoping you can find something and report back with results.
Mark: Snowman-33
gbhs72 is offline
post #5 of 7 (permalink) Old 04-06-2018, 10:32 AM
When I Searched here yesterday, I used "door Bezel Lettering" in the search. There were about 15 - 20 hits that came up so you could most likely go thru those pretty quick.
Here is another that may also give you some info. I didn't take the time to read thru all of it but there is about 50+ posts in that thread.
post #6 of 7 (permalink) Old 04-07-2018, 08:45 PM
Model train lettering comes in many fonts, and some may be close to the OEM lettering. You will probably need a clearcoat over them to keep them nice. There is also a product called Micro Sol that is designed to blend the substrate of the decal into the part surface, before clearcoating.
Architectural firms used to use burnished lettering for charts, and you may still be able to find them in various fonts. The burnished lettering was also used for model trains at one point, as well. Again, it will require a clearcoat to protect them, but the Micro Sol will not be needed. To burnish, you need a small rounded end rod, or stick to push on the backside of the "film" to release the letters, and make them stick to the part. You need to get a number of sheets, in case you make a mistake, and need to remove one or more letters. They will come of with little effort.
post #7 of 7 (permalink) Old 04-11-2018, 06:38 PM
gbhs72's Avatar
Arrow Still looking
If someone has the know how and the equipment, how about us going in on this idea?
Radio Buttons R & R - TDIClub Forums
Mark: Snowman-33
gbhs72 is offline
