REQ: Removal Tip for rear, interior, side housing - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 08-30-2018, 01:34 PM Thread Starter
juniorwatson's Avatar
The subject says it all, I don't see a real easy way to remove this plastic piece right off the bat without breaking something.
I've held up my flashlight to the area highlighed/surrounded in a white rectangular box, and don't see a small tab or anything to depress.
Tips please!
P.S. I have no idea what the black bordered ghost is doing in the right-hand side of the pic, just pretend ya never saw it...like the droids.
(Can't modify header subject header to include 'LIGHT')
juniorwatson is offline
post #2 of 5 (permalink) Old 08-30-2018, 01:42 PM Thread Starter
Well I feel silly now that I went out there and just gave a good hard PULL on the dang thing...
Boy that housing certainly can get HOT with the incandescent bulb being on for a few minutes, along with ambient being ~100' right now....
I'm going to look into LEDs for those along with the courtesy light bulbs in the front door panels, since those (the entire door panel) were recent upgrades/What did you do to your Caprice this weekend.....
Does anyone here on the forum still sell the LED bulbs? If som whos the contact?
Thx!
post #3 of 5 (permalink) Old 08-30-2018, 02:10 PM
DeuceSS's Avatar
Thx!
Ive actually had to replace those lights a few times from purchasing a low quality LED. I recently purchased a pack of 8 194 LED's from Pilot (hopefully better quality) on ebay.
One tip i can offer is before reassembling the light with new bulb verify you have the correct polarity of the bulb in the socket.
DeuceSS is online now
post #4 of 5 (permalink) Old 08-30-2018, 09:10 PM
You want access to the bulb for the coat hook courtesy light? Looks like the lens just pry's off. I would assume very carefully though....brittle plastic maybe?
https://www.impalassforum.com/vBulle...ight-bulb.html
post #5 of 5 (permalink) Old 08-31-2018, 06:56 AM Thread Starter
This thread has been resolved, I figured it out myself by just pulling on the entire thing.
