Will a 2007-2013 tahoe steering wheel fit - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 10-03-2018, 10:06 AM Thread Starter
Frasierraheen's Avatar
Sorry if this was already addressed, I was looking and I couldn't find no information on these steering wheel. But has anyone tried fitting these wheels in our cars and if so how.
Save the Wago's
Frasierraheen is offline
post #2 of 10 (permalink) Old 10-04-2018, 12:07 AM
It may fit, but will it function? It would take some serious engineering to get the controls to work.
grandpas wagon
grandpas wagon is offline
post #3 of 10 (permalink) Old 10-04-2018, 06:22 AM
gbhs72's Avatar
That was my thought too. You may have to snag the steering column and all wiring. That is if the column is a close fit. You may have opened up another mod bucket of worms.
Mark: Snowman-33
gbhs72 is offline
post #4 of 10 (permalink) Old 10-04-2018, 09:12 AM Thread Starter
Yeah the wiring would suck, but I just want the wheel, the original steering wheel is cool but I want a functional horn pad. And those monte wheels are hard to find especially the tan ones, and here at the junkyard I see these all over the place. I was just testing to waters to see if anyone has tried it before.
Save the Wago's
post #5 of 10 (permalink) Old 10-04-2018, 12:03 PM
silverfox103's Avatar
Send a message via AIM to silverfox103
Been thinking of a similar swap from a 2001 Yukon XL or similar to my Caprice wagon. No buttons or controls to deal with.
Tom
1994 RMW LAB---my toy from FL 156,000
1994 Caprice Wagon---never seen winter 105,000
1996 Cadillac Fleetwood---never seen winter 65,000
silverfox103 is offline
post #6 of 10 (permalink) Old 10-04-2018, 01:37 PM
gbhs72's Avatar
I'm going to go out on a limb here but, I think the splines on the column and the wheel will match. When I bought my wheel there was no listing for the adapter to use on my 93. I just got one for the earlier GM and it fit. The reason, I suspect, for not listing later models is the air bag. I wanted to get one from a Suburban, about 2008 model. The PnP wouldn't sell it without buying the column too.
Mark: Snowman-33
Whoops, Not 2008 but mid 80s steering wheel.
gbhs72 is offline
post #7 of 10 (permalink) Old 10-04-2018, 03:32 PM Thread Starter
I guess I'll pull some steering wheels next time I'm at the yard and test fit them on some of the b bodies while I'm there. I'll keep you all updated
Save the Wago's
post #8 of 10 (permalink) Old 10-05-2018, 09:50 AM
Another consideration for 2008-13 Tahoe wheel is they use a two stage airbag
96 DCM 1st Mod. 12way Bonneville seats!
Zebrafive is offline
post #9 of 10 (permalink) Old 10-06-2018, 09:35 PM
GM changed the mounts in the mid 90s. The wheels after that have totally different mounting systems. Someone on here or the longroof forum tried a late 90s Cadillac wheel on a B-body, and it did not work out. Airbags are different too.
I used a couple of different adapters to put aftermarket wheels on my cars. I like the look and feel of the aftermarket ones better, as well. Just be careful with the distance between the wheel and turn signal stalk.
post #10 of 10 (permalink) Old 10-14-2018, 06:12 PM
try mid to late 90's trailblazer steering wheels
http://s164.photobucket.com/albums/u6/ree9c1/Cars/
http://www.cardomain.com/ride/2223691
95 Impala SS, Stock LT1, RAISS Intake, F-body MAF, PCMPerformance tune, Try Y's headers, Clear Image stainless steal 2.5 pro street exhaust, air pump delete, no cats, LT4 knock module, Edge 2800 stall converter, Stage II trans rebuilt, 3:73 gears, posi trac, 9c1 front calipers, thicker Performance Friction Carbon Metallic pads, Pro slot rotors, ATE racing brake fluid, stealth brake bolt......
Ree SS is offline
