Parking brake cable bulkhead - MIA Spring? + Your friendly neighborhood scorpion! - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 10-06-2018, 11:24 AM Thread Starter
juniorwatson's Avatar
Guys,
I went and got the front section of the parking brake cable replaced this morning, but I think I'm missing a spring that keep tension on the lever/handle at the top. Is that right?
If I have the cable disconnected, everything functions and ratchets appropriately. As soon as I hook the cable up, the ratcheting function goes away.
I was planning on making a trip to the junkyard tomorrow anyway, so this is not a big deal, I was just hoping to have all the under-dash stuff taken care of in one shot today.
Oh well, not a show stopper, but I would like to know about a spring, and if anyone can post a picture of their assembly so I have an idea of what's going on, I'd really appreciate it.
Thanks!
P.S. Just be happy you didn't have this a$$hole hanging out in your garage, when you went and lifted up a piece of trim!
I don''t wanna read about any of you guys bitching about snow this winter. You don't have to worry about these ba$tards in your house!
juniorwatson is offline
post #2 of 5 (permalink) Old 10-06-2018, 02:04 PM
gbhs72's Avatar
Junior,
I checked mine and it appears as if all of yours is there. The only spring I saw was the one at the very top. Hope it helps.
Mark: Snowman-33
gbhs72 is offline
post #3 of 5 (permalink) Old 10-07-2018, 07:46 AM
Ain't you the guy that had one 'a them critters in the kitchen or hall?
post #4 of 5 (permalink) Old 10-08-2018, 11:39 AM
Disconnect the cable at the joint under the driver seat. See if that returns properly. If so the problem is further back.
Ken
Ken Hennessy is offline
post #5 of 5 (permalink) Old 10-09-2018, 08:11 AM Thread Starter
Ken
Thanks, I'll get back to this Friday after work, as I'll be tied up in the evenings until then.
